Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Platinum Member OrangeToys's Avatar
    Join Date
    Nov 2011
    Posts
    500
    SW Missouri
    2016 Kubota M7060HDC
    Default
    Here a pic of r4 in the mud. You can tell how deep it got and it came out of it just fine, didn't stop my momentum though
    Ag Tires vs. R4 Tires - Help Make a Decision Please-forumrunner_20130421_094312-png
    I like to push buttons that I dont know what they do to find out. Theres some I wont push anymore
  2. #32
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,405
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Default Re: Ag Tires vs. R4 Tires - Help Make a Decision Please
    Quote Originally Posted by Chilly807 View Post
    Think about turf tires as on golf course machinery. Usually quite wide so as to spread the machine weight over a larger area and reduce the pressure per square inch on the ground.
    My excavation guy told me once that his Hitachi excavator exerts a track pressure of 7 pounds per square inch on the ground. Probably explains why I nearly buried my car driving on the tracks the excavator left while he was digging my well. The car weighs a lot less than the excavator, but has a contact patch many times smaller.
    Sean
    Wide is the only possible tool to get area when there is a limit on diameter. Small dia tires cannot have a long contact patch unless they are flat. Larger dia tires can, and this gives a better ability to roll over an obstacle. In either case, wide or narrow, greater or lesser dia, the machine weight is spread over an equal area governed by inflation pressure and carcass stiffness. The soft carcass turf with inherent non disturbing tread carrying light load and run at low inflation to increase area fits everything needed on a golf course. Even tho pressure per unit area on the ground may be identical, any added width will limit rutting as described previously.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  3. #33
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,405
    VA
    Quote Originally Posted by Gary Fowler View Post
    I suppose it has to do with tire size but my LS P7010 with Ag tires doesn't squat at all with fully loaded bucket. On hard ground if feels like I have Cat tracks on it as I can feel each lug as it hits the ground but no tire squat is evident and I have reduced the air pressure a bit from max. But then again, my front tires are as large as many CUT rear tires and with a 3500 pound lift capacity, it will lift most CUTs off the ground.
    Do you have 12.4x24 front? I have 11.2x24 on the 7520. I have no squat problem at max 28psi with full bucket but thats considerably less than the lift capacity. I go up to 35 psi if Im carrying really heavy stuff.
    larry
    This side of 40
  4. #34
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,249
    Central Ohio
    Kubota MX5100
    So why do farmers run duals to reduce soil compaction when they could mearly get by with lowering the psi
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  5. #35
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,405
    VA
    Quote Originally Posted by LD1 View Post
    There comes a limit due to tire squirm and sidewall buckling. A verry long patch is fine sitting still, but half flattened tires dont roll so well ... nor last. Duals let you half the inflation and still run with good tire stance.
    larry
    This side of 40
  6. #36
    Join Date
    Mar 2013
    Posts
    127
    Connecticut
    L4600 Hst
    I was wondering how bad is your tractor on your lawn with the R4's?
  7. #37
    Join Date
    Nov 2011
    Posts
    500
    SW Missouri
    Default
    Quote Originally Posted by Express View Post
    Its not bad unless you're in 4x4
Similar Threads
  1. What difference will Ag tires make?
    By TigerfaninAR in forum Kubota Owning/Operating
    Last Post: 02-21-2013, 01:20 AM
  2. What improvement will loading tires on a x540 make for plowing
    By Scooby074 in forum John Deere Lawn & Garden
    Last Post: 05-04-2011, 01:48 PM
  3. 2 tires, what to make?
    By Johndeere3720 in forum Build-It Yourself
    Last Post: 03-02-2011, 06:24 PM
  4. Will 10 ply tires make my Expedition Rough
    By OKnewguy in forum Trailers & Transportation
    Last Post: 10-27-2009, 04:44 PM
  5. Tires Size/Make of BX Rear "Bar" Tires?
    By glennmac in forum Kubota Owning/Operating
    Last Post: 04-28-2002, 08:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
