Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
  1. #11
    Member
    Join Date
    May 2013
    Posts
    33
    Bucks County, PA
    Craftsman YTS4000; Hustler Fastrak SD 60" ZTR
    Default Re: Zero Turn Mowers
    Another one with a ZTR and love it. I cut 3+ acres with many obstacles and cannot imagine how long it would take without it. The quality of cut is also top notch.
    The downsides are: turf tires do not like the mud (but neither do lawn tractors with them), hills can be challenging, and initial cost is high.
    I would not trade it for what I have to cut though.
  2. #12
    Elite Member
    Join Date
    Feb 2012
    Posts
    3,387
    NE Indiana
    1710 Ford, Versatile 150
    I have a ZTR 60" Deines. A low cost model that has served me very well in cutting the 3-4 acres that I mow with it. It is on its 15th year now and since it cost under $5k new, I am very happy. Cut quality is exceptional! The only things I have done to it is replace blades and tires and the battery. Not one problem with anything else on the mower and my kids have driven it plenty. I have slopes that I would not take my tractor on sideways that I can mow with it. I did mow once have a time where some muskrat damage caved in the low side of the mower and i rolled it into my pond but otherwise not an issue.
    Since you do mention that you have many hills i would strongly recommend getting a model that has V-tread tires. The model I have does not have the size of tire in which they make V-treads.
    The other thing I like about mine is that it is a front deck - not a mid deck. The mid-decks go faster and take up less space but the front decks get underneath overhanging branches better such as my lilac bush and make for easier deck maintenance. So if you are not squeezed for space get a front deck!
  3. #13
    Elite Member
    Join Date
    May 2013
    Posts
    3,057
    Knox, In,
    Ford 3400, Gizmow ZTR, Simplicity 7016H
    Have a Gizmow' mower that is pretty good on grades as its front wheels are not free castoring..
    PSD Groundscare - Gizmow mowing grass lawns and banks - YouTube
    You would have to find a used one as they are gone now.. BUT, Cub Cadet bought them out and the tech is in their new line of Z-Force S zero-turns..
    Z-Force S Riders: Find Zero-Turn Mowers with Steering Wheels
    EDIT: had to look it up.. The Gizmow 61" weighs 1600lbs!
  4. #14
    Platinum Member OrangeToys's Avatar
    Join Date
    Nov 2011
    Posts
    500
    SW Missouri
    2016 Kubota M7060HDC
    Default
    I own 4 scags and have driven several other brands and nothing beats my Scag mowers
    I like to push buttons that I dont know what they do to find out. Theres some I wont push anymore
  5. #15
    Veteran Member DmansPadge's Avatar
    Join Date
    Oct 2004
    Posts
    1,678
    Orange, TX
    Kubota B2620, Toro 2000 Series Z Master
    Default
    I have a Toro Z Master that weights 1000 lbs. My land is flat but I have a steep ditch that is almost 400' and it holds it very well. I've mowed that same ditch with garden tractors and my kubota tractor and feel the safest on the Toro.
    As for brands.. There are a lot of good ones out there. I would start with brands you have local to you and go from there. It's also good to note what the pros are using in your area as that brand is probably working out good for them.
  6. #16
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default
    I have a john Deere z465. Great machine. The slopes is an operator problem I think. Firstly, stay away from slopes when its wet, but who mows in the rain anyway(but still be aware of morning dew and the like). Second thing I have discovered is its unnatural traction behavior. Only two wheel have traction, the two fronts are only casters so they provide no directional control. So if you start to loose traction don't pull back on the levers but rather accelerate the down hill wheel( its the only wheel with traction). Once you manage to figure that out you will do great on slopes(this comes from a prairie guy who only deals with ditches). I wouldn't worry too much about wheel spin damage on turns, again be reasonable stay away from wet grass. Any damage is unnoticeable after weeks worth of grass growth.
    Although ztrs reduce mowing time, you may not notice a hugh difference since your only mowing 2 acres. With my mower you'd in about 45 minutes max, you may only save 20-30 minutes. On my 7 acres I figure my mowing goes from about 5.5 hrs to 3.5 hrs.
    One last thing, my particular model doesn't have rops. If it were me, with slopes you have, I'd want that feature. But that's me.
    Good luck in your hunt for the right machine for you.
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  7. #17
    Platinum Member Monster5601's Avatar
    Join Date
    May 2010
    Posts
    664
    Oakland, MI
    Kubota B3030 R4 Tires
    Quote Originally Posted by George Roesner View Post
    I need some help. I am looking at getting a new mower and I want something built to last and cuts grass evenly. I think a zero turn is what I want but I need help clarifying this: Are zero turn mowers terrible on grades?
    Next question: What do I buy? I only have 2 acres to mow, quite a few hills.
    kubota, Husqvarna, Bad Boy, Toro, John Deere? Other? Any suggestions or feedback? What are your experiences with your zero turn? Good/bad?
    Quote Originally Posted by Biggreenavalanche View Post
    Like PMA said, best thing since sliced bread...I have a ten year old x-mark, mow two acres(more or less) and will never go back to conventional, regardless of higher cost ! The only drawback is they suck in ANY mud...I'll live with it...
    I had the same decision to make two years ago when (one of many) my big box mower quit. I was willing to buy one more mower, it had to last forever (I'm near retirement age), had to cut three to four acres, my grass in the spring is usually wet so it had to manage wet grass. My tractor dealer suggested a ZD series mower. He send one out for me to try and the ZD323 stayed with one modification, he changed out the rear tires from turf to industrial. Since the rear tire switch, the ZD easily navigates muddy areas. And, the ZD reduced cutting time from three hours to around one and a half hours.
    The ZD323 is a diesel, it uses around three quarts of fuel to mow. The old two cylinder air-cooled big box mower used about two gallons to mow the same area.
    Bob, n8zcc
    Kubota B3030 with R4s
    LA403, 60" bucket with hooks, bolt-on tooth bar, ratchet rake
    BH76 with 16" bucket and thumb
    Kubota Pallet Folks
    Bush Hog 35-06 72" Rear Blade
    Bush Hog SBX60 Box Blade
    Bush Hog Razorback RZ160
    Bush Hog RG72 Road Grader
    Kubota ZD323-60
    Kubota RTV900 with Curtis hydraulic angle plow
  8. #18
    Join Date
    Dec 2010
    Posts
    216
    Quincy IL
    New Holland TC 30
    I too have a zero turn Lazer Z eXmark the turf tires suck I have replaced them with carlisle bar tires. Makes a completely different machine. Hills need to get used to, but they are no problem after that. It cut my mowing time in half, from my cub Lo-Boy same size mower.
  9. #19
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,622
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    With hills I recommend a front deck 4WD mower.
    Read this thread: http://www.tractorbynet.com/forums/k...-f-series.html
    Search eBay for Toro Groundsmaster. toro groundsmaster | eBay
    and front deck mower. front deck mower | eBay
  10. #20
    Gold Member
    Join Date
    Nov 2012
    Posts
    283
    Montgomery, AL
    craftsman lt1000/jd 717a/ mahindra max26 hst
    I've got a JD 717a. it's... old.. (well, ok, not in years, i think it's only 6, but it's "high mileage" at around 2400 hours or so) but fantastic. I bought it used last year from a landscape guy when we bought our new house, and it's absolutely a blast to cut with. I think I've put around 150 hours on it since I got it, and I'll need to get some new blades here real soon. I cut ~3 acres +- in about an hour and a half, in and around obstacles, etc. the cut is fantastic, the turf tires as others have said occasionally prove inadequate, but if you've got hard clay in the summer time it's fun to drift the lawnmower through the turns.
    The way I use mine, if I got the paddle style tires my yard would be destroyed :-D I may put a set on my lawn tractor to make cutting the ditch easier though..
Similar Threads
  1. Zero turn mowers
    By GRIFFKILL in forum Owning/Operating
    Last Post: 11-08-2011, 04:55 PM
  2. Zero Turn Mowers Again
    By swinn5567 in forum General Lawn & Garden
    Last Post: 05-17-2009, 01:14 PM
  3. Why zero-turn mowers?
    By RayCo in forum General Lawn & Garden
    Last Post: 03-28-2008, 10:31 PM
  4. Zero turn mowers
    By Nat in forum Buying/Pricing/Comparisons
    Last Post: 10-10-2004, 09:57 PM
  5. Zero Turn Mowers
    By Richard in forum Rural Living
    Last Post: 09-18-2003, 03:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
