Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Default Re: So now I have the tractor, now what??.
    I use my QA pallet forks more than I use anything else...hands down. a 66" EA Wicked Grapple is on the short list to buy as well.
    If you're going to seriously use the FEL, you're going to need a counterweight, and hanging an implement off the rear doesn't really do the job properly (not enough weight, and they stick out far enough to bump into things frequently. For your tractor, you're going to want a minimum of 1,000lbs. I got lucky, and found a 1,300lb hunk to steel at the local scrap yard, and turned it into a counterweight with a little help from my neighbor.
    All of the brands of rotary cutter already mentioned are good, but I'd add Rhino...very heavily made stuff. Don't overlook quality used cutters....if you know what you're looking at, you can save a lot of money on them. As long as the deck is solid, everything else can be replaced pretty easily if need be....when you look at $1800 for new, and $500-750 for the same unit used, it makes that choice easy, assuming you have the tools and ability to work on that sort of stuff. I recently bought a 5" hog in really good shape, that had a bad gearbox. I got a factory (Omni makes almost all of them) gearbox, and new set of blades, and all told I have right around $600 in it, and it runs like a new unit.
  2. #12
    Join Date
    Jun 2013
    Posts
    53
    Russia, NY & Socialist Republic of NJ
    2013 Kioti DK40SE HST
    Do you all recommend weights? Tire weights or suitcase type? What about tire filling?
    Also, I have a maple farm and will be doing quite a bit of logging to release my maple trees...who has experience with various winches available (Farmi, Norse etc)? Boy they are expensive !
    Can you use a crane arm an chains?
    So much fun looking at all this stuff! Of course this could be more than the tractor !
  3. #13
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    No longer Searching. Mahindra 3016 Shuttle
    Jmsmithy,
    If you did not get a front loader with your tractor, you owe it to yourself to look at Westendorf front loaders before making a decision about one.
    www.loaders.com for Westendorf loaders and the other products.
  4. #14
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,530
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds
    Quote Originally Posted by Jmsmithy View Post
    I do not weight my tractor permanently with wheel weights nor filled tires. Permanent weight has major disadvantage of compacting the soil/lawn and minor disadvantage of increasing fuel usage. Consider repairing a puncture in a filled rear tire....
    When I need weight I mount an implement on the 3-Pt. hitch. Ballast on the 3-Pt. gives improved traction, and weight behind the rear axle relieves stress on the front axle when you are working with a max load in/on bucket, which for me is log sections ~ neither filled tires nor wheel weights relieve front axle stress.
    On occasions, you cannot pick up a max bucket load without rear ballast. Instead of the bucket coming up, the tractor will kneel and you are really stressing it.
    If you think you need more permanent tractor weight buy a tractor with a heavier frame.
    My 60" wide tractor moves through the woods well. I have rarely feel desire for a winch. I skid using an Omni Hanging Tree mounted on an Omni Cross-Drawbar Stabilizer, which Omni calls a combination hitch. You drag logs CAREFULLY to an accessible area with chain attached to the (TSC) cross-drawbar, then raise log with Hanging Tree to transport safely. Had I to do it over I would consider a Northern Tool Log Hog*. Omni now offers a Log Boom, I see.
    (If a log being dragged encounters an immovable object [boulder, rock ledge, burrow etc.] while the tractor is powering forward, the tractor can go vertical on its rear wheels in a heartbeat. A heartbeat! )
    On my "learning" tractor, a loaned John Deere 750, I skidded logs without dedicated skidding equipment. As a result I tore the Meniscus in my right knee. Result: 12 weeks of physical therapy and knee surgery = $18,000 plus, plus, plus. Mr. Natural says: "GET THE RIGHT TOOLS". Why didn't I listen?
    I have industrial tires, R4s, most compact tractor/loaders come equipped with R4s.
    In everything having to do with my tractor I try to observe the KISS Principle: Keep It Simple, Stupid.
    OMNI Grabhook Hanging Tree - OMNI Mfg LLC
    Norwood Log Hog Log Skidder Tractor Attachment, Model# 41255 Log Hog | Log Skidding| Northern Tool + Equipment
    *Try to ignore dangerous dragging chain in Log Hog video.
    Attached Thumbnails Attached Thumbnails So now I have the tractor, now what??.-img_0378-jpg   So now I have the tractor, now what??.-img_0376-jpg   So now I have the tractor, now what??.-img_0335-jpg   So now I have the tractor, now what??.-img_0623-jpg
  5. #15
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    In general, weight helps traction. Wheel weights, and loaded tires are the ticket for pulling ground engaging implements, but not very helpful when using the FEL.
    Without a rear counterweight, my tractor can only lift a bit more than half the loader's rated weight. It's listed as lifting 2,640lbs to max height, at the pins. It was getting very light on the rears when lifting the 1300lb slab for my counterweight, and slightly lifted the rears a few times. Add the weight of the pallet forks, and it was lifting something like 1,700lbs....but it wouldn't have been safe on anything but the flat concrete I was on.
    Check your manual, and it'll probably give you an exact figure for what the recommend for counterweight. Here's mine:
  6. #16
    Join Date
    Jan 2011
    Posts
    6,530
    Rodin, Matisse, Picasso, Toulouse Lautrec......they would all be proud to have created this.
  7. #17
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,138
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by GManBart View Post
    Why is your tractor rated to lift 140# more than mine?
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  8. #18
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by TSO View Post
    Because I read the loader manual, not the website!
  9. #19
    Gold Member
    Join Date
    Jan 2012
    Posts
    329
    Southern Oregon
    Kioti DK45SE Hst
    My most valuable implement is the backhoe. Lots of people may disagree but I'm constantly digging water lines for irrigation around the house, digging out a stump, etc. And it makes a great counterweight. With fluid filled back tires and the backhoe sticking out the back, I've only had the back tires off the ground maybe 2 times: once with a heavy load of lumber on the forks (also a great implement, especially for construction), and the other time when pulling a log out of the forest backwards. When building my barn, I threw an empty pallet on the forks and had a simple but very effective man lift.
    I wouldn't get the winch. Use something like a snatch-block to winch your log close enough to chain directly to the tractor. Then just pull it to where you want to buck it.
    Marcus
    Kioti DK45SE HST w/ backhoe, forks, PHD, box blade, chipper. Living off-grid, Listeroid 6/1 backup, masonry stove, thermal mass H2O storage
    "Those who would give up Essential Liberty to purchase a little Temp Safety, deserve neither Liberty nor Safety." Ben Franklin, 1775
    "The 2nd Amendment is the RESET button of the US Constitution"
  10. #20
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,359
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Hello All
    Thanks to all your advice, I finally de my decision and purchased the Kioti DK40SE HST.
    I have 250 acres, food plots, 300+ yard rifle range, maple syrup farm. I log ( firewood for the maple evaporator plus my two wood stoves), hunt, fish make syrup etc etc...
    Have multiple atv's as well as snowmobiles.
    All that being said, what do you think should be the first purchase as far as implements go?? I think I'm going Brush Hog first....any suggestions as to brand? Also what other implements do you all like???
    With only 34 hp (pto), I'd go for a 6-ft brush hog and keep it out of the heavy bush. Mine is a Hawkline that cost about $1100 5 years ago.
    Other implements: depends on the jobs (near term and far term future) you anticipate. Can't help you until you clue us in on your plans.
    Good luck.
Similar Threads
  1. Replies: 5
    Last Post: 05-14-2013, 11:50 PM
  2. Replies: 3
    Last Post: 10-30-2012, 08:51 PM
  3. Replies: 4
    Last Post: 11-10-2009, 01:41 PM
  4. Replies: 2
    Last Post: 07-06-2009, 10:00 AM
  5. Peer review/help for BX size tractor as multipurpose yard tractor
    By imajeepnut in forum Kubota Owning/Operating
    Last Post: 04-12-2009, 09:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
