k0ua
Epic Contributor
You might want to check with TBN MtnViewRanch as he sells all this sort of thing reasonably priced through Fit-Rite, I have a hydraulic top link on order with him, I got the factory remotes from Kubota as they offer three.
Mike notice in his first pic, down below the PTO stub is the drawbar on his Kubota. Yours is about the same. All you need is a clevis sometimes called a shackle. Make sure that your drawbar will fit between its "ears" and it is large enough to pass your grab hook thru its "eye". I use a short 6 foot chain with a grab hook on one end and a snap hook with retainer on the end that I snap onto the clevis on the draw bar, and hang the grab hook end off of my ballast barrel. Then when I need to hook up to another chain the grab end is conveniently positioned to hook up or "grab" another chain without having to bend over all the time to mess with the clevis. You see you are pulling from a point that it made to pull heavy loads from, by the manufacture, and it is below the axle centerline so your tractor will not turn over backwards. Never pull from a high point on your tractor, like for instance a top link hole or something like that.. sure way to die.
James K0UA
1 1/4 X 3 3/4 Twist Tractor Clev
