Page 2 of 27 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 268
  1. #11
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,385
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    When I was shopping I was stuck between a JD 4520 and kubota 5240, what made the final decision for me was that the Kubota was a little more comfortable driving around the lot. The adjustment in the seat and steering wheel just allowed me to be more comfortable. I would spend as much seat time as they will allow you to try and see which one fits you better as both are very good tractors.
    As has already been said you cannot get a full appreciation for the hst+ tranny at the dealer. If you buy the Deere you won't know what you are missing and will be happy with it, but the hst+ is awesome once you get the hang of it. When you get good using the features it saves time and makes the tractor more enjoyable to operate.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  2. #12
    Join Date
    Jul 2013
    Posts
    99
    Hastings, Mi
    JD4120
    Default Re: John Deere 4120 V.S. Kubota Grand L4060 w/ prices
    Quote Originally Posted by 94BULLITT View Post
    Thanks, is the 400CX the smallest loader that it is available on?
    Can't say. I just know it is available on the 400x and 400cx.
  3. #13
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Quote Originally Posted by ovrszd View Post
    I know nothing about an LS tractor. But are you saying it has all the features of the Deere or kubota?? Think about that carefully before answering. Not picking on your tractor, just saying I've heard this conversation before. Then when it gets right down to comparisons the difference list seems to grow.
    No need to think all that carefully about it...it's not exactly life or death
    I'm certainly not a tractor information database, but from what I can recall, the Deere and Kubota have less standard features, in general. If you compare a shuttle-shift version of the Deere, Kubota, to an LS or Kioti, the latter two will have more features standard. When you look at the Deere, and Kubota, some of their optional features are more complex than a similar feature on the LS or Kioti, and are often different enough to be considered a separate feature by itself (i.e. HST+ is a more complex HST system). I guess it depends on whether you want to look at standard features, or possibilities.
    Still, even if you give the Deere (or Kubota) all of the optional features the math doesn't make much sense to me. Just take the Deere to LS comparison, for example. Both are 4x4 CUTS, that come with 3-range HST transmissions, differential locks, FEL, 540 PTO and 3pt. The Deere 4120 has 43hp, 35hp at the PTO, 3pt lift of 3,130 at the ends, FEL lift of 2,339lbs to max height (111"), and weighs 3,700lbs without the FEL. The LS R4047H has 47hp, 38hp at the PTO, 3pt lift of 2,755lbs at the ends, FEL lift of 2,638lbs (website is wrong) to max height (96"), and weighs 3,813lbs.
    Both have tilt steering, two-pedal HST controls, adjustable seats, electronic cruise control, and folding ROPS.
    The LS also comes with telescoping link arms standard, dual rear remotes standard, rear work light standard, larger wheels/tires, a 7-pin trailer plug standard, and a 5yr powertrain warranty.
    As best I can tell, the Deer only exceeds the LS in FEL lift height, 3pt lift max, a self-leveling loader bucket, and an HST system that offers two modes not found on the LS.
    The LS has more power, more PTO power, more FEL lift capacity, bigger wheels/tires, draft control, and 3yrs more warranty coverage.
    Seriously, I can see where there is some value/utility in a self-loading bucket, or the eHydro features, but an extra $10K?
    Know what I did with the $10K savings? I bought another tractor (in a new color) to dedicate to mowing!
  4. #14
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Your LS lifts 11lbs more to full height on the loader than the kubota. It weighs about 140lbs more than a L4240.
    Actually, that's not correct. The LS website has old data on it for some reason. The current LL4101 loader lifts 2,638lbs to max height at the pins and the breakout force is 4,354lbs.
    For so much less money, I can handle only being able to lift 150lbs or so more
  5. #15
    New Member
    Join Date
    Aug 2013
    Posts
    7
    BORING OR
    NONE
    SSQA is a $600 upgrade with Deere. I don't know if it's available on smaller loaders.
    We plan on the tractor wearing many hats around here. We will be farming nursery stock and maintaining our modest 5 acres.
    Thanks for the great replies. I still can't decide.
  6. #16
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,947
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Quote Originally Posted by HARRISONM3 View Post
    Understandable, but the good news is that you will be happy with either and have a good tractor. Same goes for several other top brands.
  7. #17
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,762
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Quote Originally Posted by MtnViewRanch View Post
    ovrszd, you say that you know nothing about LS tractors and yet you say This sounds like you must know something about them?
    Nope Brian, I stated up front I knew nothing about LS Tractors. I also didn't mention ANY brand names when I made the statement about comparisons. Not picking on anybody. Just stating that when it gets down to picky comparisons the difference list seems to grow.
    Some of the differences might not matter to you at all. But they might be huge to me. The smallest differences can be gigantic after a few hundred hours of use. Here's an example, I don't like a 4 speed trans with 3 ranges to get 12 speeds. I prefer a 6 spd tranny and 2 ranges. That might not matter to you at all
    That's why I offered the advice of drive what you can as long as they'll let you and you'll have a better chance of figuring out what differences top your personal list.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  8. #18
    Gold Member eagle107's Avatar
    Join Date
    Jul 2011
    Posts
    376
    NY
    John Deere and New Holland/Ford Tractors
    Default
    I would make sure you do your own research and have all the fact in hand when making your decision. Both the Deere and kubota are the top tractors in this class and size tractor at the moment, though the new Massey Ferguson 1700 models are looking good. Just be aware that not everything being stated on this thread is accurate.
    John Deere and New Holland/Ford Tractors and stuff
  9. #19
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by eagle107 View Post
    What did anyone say that was inaccurate....as in factually wrong?
  10. #20
    Join Date
    Jul 2012
    Posts
    1,131
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    I don't think the LS loader is more powerful than the 400cx....Deere rates the loader 18 in forward of the piviot with a standard bucket. The LS has an indirect injected engine as opposed to direct injected as in the john deere powertech engine. the JD has glow plugs instead of the preheat of the LS. The JD has 12 gpm of implement hydraulic flow opposed to 8 gpm on the LS.
    I'm sure the LS is a good tractor for the money...but it's no John Deere 4x20.
Similar Threads
  1. Thermistor, John Deere 4120
    By jsteven in forum Parts/Repairs
    Last Post: 05-18-2013, 04:21 PM
  2. Which rototiller for a John Deere 4120?
    By 12VOLTMAN in forum Attachments
    Last Post: 06-13-2009, 10:18 PM
  3. John Deere 3120 against a Kubota Grand L3130
    By epic6500sr in forum John Deere Buying/Pricing
    Last Post: 10-31-2007, 02:23 PM
  4. John Deere 3720 vs. 4120
    By ArtVandelay in forum Buying/Pricing/Comparisons
    Last Post: 07-03-2007, 08:51 AM
  5. 4120 john deere ehydro
    By burbank227@aol.com in forum John Deere Owning/Operating
    Last Post: 07-30-2006, 08:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
