Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
  1. #31
    Member
    Join Date
    Feb 2013
    Posts
    27
    upperco md
    jd4250..820
    Default Re: Kubota L3800 -vs- L4600 For Stumping Etc.
    Kubota L3800 -vs- L4600 For Stumping Etc.-sunflowers-2013-003-jpg
    This tractor has a loader and the last thing I would want to do was push trees...This tractor weighs 20k lbs., yet it was not designed for it
    Break anything, and the rental cost on a track machine will be pocket change
  2. #32
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,206
    Central Ohio
    Kubota MX5100
    I'd push trees over all day long with that. It could handle far bigger trees than my kubota. Probably not as big as the BH, but likely lots more maneuverable in the woods without a 13-1/2' high BH boom hanging off the back.
    Loaders WERE designed to push. And not everyone can afford a single purpose track machine that makes a mess out of the yard if you have to drive across, and God forbid have to turn.
    Dont get me wrong, I would love a tracked machine. But cannot afford one. So I make do with what I have.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  3. #33
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Quote Originally Posted by k0ua View Post
    The L4600 does not have hst+.. it is a "standard" tractor like the L3800.. These are base models not Deluxe models.. They do not have as many features as the Kioti DK lineup.
    You're absolutely right....for some reason, I always forget that about the 4600, but remember it about the 3200 and 3800.
  4. #34
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,968
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Quote Originally Posted by LD1 View Post
    You and I; just ONE kubota each.
    The word tractor was taken from Medieval Latin, being the agent noun of trahere, "to pull, draw".
    Kubota B3300SU; no longer with me but still pulling in the community.
  5. #35
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    I would sell the the big tress off as verneer hire a logger for that and they will pay you for the good wood I would not want anything less then an mx5100 I had an L3800 I traded it in after 2 months fel wasn't strong enough and its was alittle light when I find a used 8540 or a 9540 the 7040 is gone just my 2 cents
  6. #36
    Member
    Join Date
    Feb 2013
    Posts
    27
    upperco md
    jd4250..820
    You are 100 percent right about tearing things up...I try not to turn it on anything of any value....I took it across the corner of my barn apron and it cracked it up the middle...I only use it for special projects, and I'm looking to sell it in the future.
  7. #37
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,715
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Quote Originally Posted by dave9652 View Post
    Dave, Check out the links I posted for some pics. You don't need a dozer for land clearing, I do it all the time with my little "tonka toy" In fact, it's the primary purpose I have. Keep in mind I also have a full sized industrial backhoe as well, and I still use the Tonka toy over the backhoe. Unless your clear cutting (which it doesn't sound like the op is) then a compact tractor can often do just as good of a job, if not better (albeit slower) without making nearly the mess of an industrial machine, and not damaging much of the stand in the process. In fact, some forestry stewardship and management plans actually specify that heavy equipment NOT be used in selective harvesting.
    Now, if he was clear cutting, that's a different story. But it doesn't sound like he wants to level the place and put a development in.
  8. #38
    Member
    Join Date
    Feb 2013
    Posts
    27
    upperco md
    jd4250..820
    Kubota L3800 -vs- L4600 For Stumping Etc.-ruts-jpg
    I used the loader on the side of a hill pushing stumps and large rocks...The CG on a tractor is to high for my liking when it come to clearing anything on rough terrain. I like equipment to go in the direction I point it.. The tractor will not steer well pushing and tapping a brake to keep it where it belongs...I like to get er done and move to the next project....There's a lot of cheap horsepower out there, so why buy new...Don't laugh, but pretty near every piece of equipment I own come off Craigslist or a distressed owner
  9. #39
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,135
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Quote Originally Posted by Konabrian View Post
    Very large trees. the majority of them are even a challenge for my Husqvarna saw and when blocked up to 18", I can barely lift them onto the splitter until they've dried out a bit.
    If your trees are that big it's a waste to burn them. My most expensive "attachment" is my LT10.
    Kubota L3800 -vs- L4600 For Stumping Etc.-8x6sam_0365-jpg
    The base cost new was about $3,000 before extra blades etc. After I load a tree on the mill it takes about 8 months and 1 hour to turn a 10' log into 150 board feet of lumber air dried. That's 1 hour for the sawing and 8 months for the drying. So far I've only produced about 500 board feet and have used most of it for shelving. But I had to clear those 3 trees anyways.
    And when you mill trees you get the outside cant or flitch which is very suitable for firewood.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  10. #40
    New Member
    Join Date
    Aug 2013
    Posts
    8
    Burlington, VT
    Massey Ferguson 1635
    How's this to throw a monkey wrench in the works. My wife took me to a Massey Ferguson dealer and we both were very impressed with the 1635 with the FEL. Looks like the package that would come closest to the L3800 will be a couple grand more but it seems like a lot more tractor in many ways.
    Stay tuned for the saga!!
    Brian
Similar Threads
  1. Kubota L4600
    By hfd525 in forum Kubota Owning/Operating
    Last Post: 01-18-2014, 01:02 PM
  2. Buying Advice Kubota L4600
    By Cotjockey in forum Buying/Pricing/Comparisons
    Last Post: 08-05-2013, 04:28 PM
  3. Buying Advice Which Tractor......Kubota L3800 or L4600?
    By bossgobbler in forum Buying/Pricing/Comparisons
    Last Post: 05-29-2013, 01:03 PM
  4. kubota L4600
    By harry1965 in forum Kubota Owning/Operating
    Last Post: 09-18-2012, 10:32 AM
  5. l3800 versus l4600
    By Drdriller in forum Buying/Pricing/Comparisons
    Last Post: 09-04-2012, 09:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
