Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    7,066
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Default Re: Looking to buy my first tractor, need advice on what to look for
    Quote Originally Posted by nfernandez View Post
    The Allis Chalmers is a 1947, and I know they have 3 point hitch conversions available. Attached is an image of the back end, can you tell if it has the conversion?Attachment 335379
    Link shows standard Three Point Hitch dimensions:
    TractorData.com - Three-Point Hitch
    The word tractor was taken from Medieval Latin, being the agent noun of trahere, "to pull, draw".
    Kubota B3300SU; no longer with me but still pulling in the community.
  2. #12
    Join Date
    Sep 2013
    Posts
    58
    Byron Center, MI
    John Deere 2210
    Quote Originally Posted by Grandad4 View Post
    The WD is a nice antique, but it's not likely to be a reliable partner for your routine work... you'll spend more time keeping it running than using it. As others say, a number series Ford, or maybe a Massey Ferguson 35 or 50, or something else with a good 3 point setup and live pto would be a better choice. Finding one in good condition is more important than what make it is.
    Nice property, by the way.
    Thanks!! Someone above mentioned an Oliver 550, and there is one on craigslist that seems pretty nice. 1964 Oliver 550 tractor I actually like the idea of having a front loader just incase i need to haul landscaping around or move snow that the rear blade can't move. Thanks again for the input, this is all very helpful.
  3. #13
    Join Date
    Sep 2013
    Posts
    58
    Byron Center, MI
    John Deere 2210
    Quote Originally Posted by Gary Fowler View Post
    Overall, I don't think you can beat an old Ford like the 861 or even early model 2000 or 3000 might be had within your budget
    If you had to pick one of the Fords listed (641, 861, 2000, 3000) what would you choose? It seems all of them are readily available in my area and are very close to my budget.
  4. #14
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    The bucket on the Oliver 550 looks like someone built a snow pusher which could be handy for your drive. I'm not sure the bucket dumps from the pic ?
    There is a lot of info out there if you do a Google search on Oliver 550.
  5. #15
    Elite Member
    Join Date
    Jan 2010
    Posts
    2,540
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    The loader looks like a home-brew... maybe some kind of trip bucket. It may be OK for light use. The factory loaders of that era tended to be very heavy for the tractors they went on and often overloaded the front axles of what they were mounted on. Often gave your arms a workout too since not all of those tractors had power steering! The Oliver might be a good choice... be sure to check the front end for excess wear due to loader.
  6. #16
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,973
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Byron Center is located in west Michigan. The Allis Chalmers is a 1947, and I know they have 3 point hitch conversions available. Attached is an image of the back end, can you tell if it has the conversion?Attachment 335379
    To give more detail on the Allis Chalmers, the oil leaked out of the engine over the last two years while it hasn't been ran. Prior to that, it worked great. So it will take some work to get it going again, I am just trying to figure out if its worth my time. Am I better off just spending $3500 on a tractor that has a wide front, 3 point hitch, and live PTO? Or getting this free tractor and putting $1000 into it to get it running and converted to use 3 point hitch attachments?
    That tractor doesn't even have the AC linkage attached. SO the answer is not it is not 3 PH ready. It may be hard to find all the parts necessary to put a 3 PH on it also.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #17
    Member firstfruitsfarm's Avatar
    Join Date
    May 2008
    Posts
    43
    Travelers Rest, SC
    Farmtrac 555, Ford 3500 TLB, Ford 9N
    When I was a kid, the farm where we lived (NH) had an AC WD and a CA. Both were fitted out with snow plows and did a good job all winter. I think a rear blade would not be good for a 500 ft drive through the season. You'll spend much more time in the cold and dark pushing backwards with your neck twisted around. If you add decent lights, you'll need an alternator to keep from draining your battery using the original generator. The ACs had undersized axle drum brakes that would wear brake bands out quickly. You would soon wear your leg out trying to keep the tractor straight when pushing. A failed seal at the transmission leaks oil over the brake bands and makes the brakes useless. You'll strain your lift arms pushing piles back late in the season. The Ford 3000 or equivalent would be much better. If it came with a loader, you could adapt a used snow plow to it that would be good enough for 500 ft and get you back in the warm much sooner. With only a 1/4 acre garden, you might be better off with a 3PH tiller than getting plows, harrows, cultivators, etc. You might find a good medium duty bush hog used, and come in pretty close to your budget.
  8. #18
    Join Date
    Sep 2013
    Posts
    58
    Byron Center, MI
    John Deere 2210
    Thanks for the feedback. I am starting to lean away from taking that tractor as I feel it will just cause problems and I am probably better off spending a few thousand and get something I can use for many years. I am really leaning towards the Ford 2000. Seems to have good power, power steering, can handle a loader and its within my budget. My question now is, what version of the Ford 2000? There is the '62-'65 4 cyl, or the '65-'75 3 cyl. Both have almost the same HP, live PTO, etc. Is the 3 cyl better that the 4 cyl?
  9. #19
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    There is a member here, SoundGuy, he can tell you the pluses and minuses of those Ford questions. I suggest you send him an email (private message) from your TBN home screen. He has run down the differences several times on various threads, but that is hard to find.
  10. #20
    Join Date
    Sep 2013
    Posts
    58
    Byron Center, MI
    John Deere 2210
    Quote Originally Posted by dave1949 View Post
    Thanks, I'll get in touch with him.
Similar Threads
  1. To buy or not to buy....Hustler Super Z Diesel 72"
    By MonkeysTractor in forum Buying/Pricing/Comparisons
    Last Post: 08-29-2013, 11:40 AM
  2. Buying Advice About to buy, advice and sanity check requested (includes prices)
    By dkair in forum Buying/Pricing/Comparisons
    Last Post: 08-18-2013, 09:21 AM
  3. Buying Advice which tractor to buy?
    By chad26 in forum Buying/Pricing/Comparisons
    Last Post: 08-03-2013, 11:22 AM
  4. Buying Advice To buy a tractor or not?
    By PSUTundra in forum Buying/Pricing/Comparisons
    Last Post: 07-09-2013, 08:42 PM
  5. ? Did i buy right tractor
    By aosmith in forum Buying/Pricing/Comparisons
    Last Post: 07-06-2013, 10:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
