murphy1244
Epic Contributor
- Joined
- Nov 25, 2011
- Messages
- 20,038
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Check out a Kioti and save 10 grand over Kubota. Even has a Horn and Rear 3 point Control.
PLUS it had to be about $15K (per my agreement with SWMBO)Critical parameters I see are:
I need to be able to lift about a ton on the 3pt.
I want about 40HP, but not more than probably 55 because it's too big
to maneuver in the woods.
I need 4 WD or MFWD.
I've got to have a FEL.
I would strongly prefer HST but could live with shuttle type shift, I
don't anticipate doing a LOT of FEL work. I've used a 30hp SATO with
standard and it worked ok for my needs.
Turf tires won't do.
Tractors are pretty much open outside machines, that "new tractor smell" goes away pretty quick.
My bad there folks - didn't know there was a specific Kubota forum...but I do now!
Ultimately I don't care what color my future tractor is or what logo it has on it so long as it is well built, performs as designed and is on the lower end of the maintenance cost scale. I would honestly pay double up front for something that rarely breaks rather than get shut down in the middle of projects and spent countless hours on the logistics and frustration of getting it fixed (and probably paying more in the long run for the pleasure).
After learning JD and New Holland both sub contract out different components in their manufacturing process and that Kubota is all "in house" it was an easy step to focus on Kubota...plus that L2600 I occasionally borrow has had little downtime over the last 13 years I've been in the neighborhood. Not sure if sub-contracting out is true for Kioti, Mahindra or others so I'm still open. When I search for each manufacturer on Google Maps there are a LOT more kubota dealers in VT/NH where I'll be living the rest of my life than the others.
That said, keep it coming - I've got more leads to chase down than I know what to do with!
