Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    1
    tiplersville, MS
    john deere
    Default John Deere 5055E w/ FEL vs. Kubota MX5200 4 wheel drive with FEL
    I am currently in the market for a new tractor to replace the JD2150 I just sold. I am looking at a John Deere 5055E (4 wheel dirve) w/ FEL and a kubota MX5100 4 wheel drive with FEL
    Kubota is about $4000 cheaper but I never had a Kubota and don't know if i would be satisified. I have had JD's for about 20 years. Almost all I do is bush hog and spray the pastures.
    Any pros and cons on either.
    thanks, i appreciate any help you can give me.
  2. #2
    Veteran Member Bigfoot62's Avatar
    Join Date
    Aug 2008
    Posts
    2,175
    W. Central Louisiana
    JD 5083E; JD 5085M; NH TN70A; Ford 2600
    Default Re: John Deere 5055E w/ FEL vs. Kubota MX5200 4 wheel drive with FEL
    I think both are good machines. Dealer support would be a factor.
    Looking at the TractorData specs, the JD is 1800 pounds heavier and has a higher 3 point hitch lifting capacity. The JD also a better hydraulic flow rate.
    I'd say that the JD is going to be a closer match to the tractor you just sold. If you go orange, you'll need to go bigger to get a close equivalent.
    '12 JD 5083E Cab MFWD FEL
    '10 JD 5085M Cab MFWD FEL
    '07 NH TN70A MFWD FEL
    '81 Ford 2600
    Vermeer 504R round baler; JD 265 & Kuhn GMD 600 disc mowers; Sitrex V-10 rake; Krone 5.52 Tedder; Hardee 10', Rhino 7', & Modern 5' rotary mowers; JD 13' & Ford 6' tandem discs; HayKing 10' rennovator plow (sub-soiler); etc, etc.
    My other tractor is a '95 Kenworth.
    "I've come to the point in my life where I can't remember if I've lost my horse or just found a rope."
  3. #3
    Elite Member CobyRupert's Avatar
    Join Date
    Oct 2012
    Posts
    3,351
    Washington County, NY
    JD 5075E
    For me, a big issue was the JD's having a seperate PTO clutch/lever, independant from the transmission clutch pedal. Not sure 'bout the MX5100, but many of the 'Bota's I was looking at had a 2 stage clutch pedal /combo. Just didn't want that.
    JD5075E, Frontier RC2084 Rotary Cutter, Wallenstein FX65 Skidding Winch
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    MX5100 has a hyd controlled wet pto clutch very similar to the JD 2150 unlike the dry pto clutch on the JD 5055E built in India. I still can't believe JD engineers haven't found a cure after all these years for the temp switch that has a long history of failures for the "cold start advance"
  5. #5
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Kubota L3800DT, L3750DT Shuttle
    I'm also looking at these two models to replace our old L3750. I've been back and forth, but leaning hard toward the MX5100 now. The JD does look good, but I hear of folks having problems with newer JDs'. I also prefer the 2 stage clutch of the MX. Having 3 Kubotas in 30 years with no major problems is a strong pull for me to stay with orange too.
    Don
    Kubota L3750 Hydro Shuttle, 4wd, FEL; L3800 Gear drive, 4wd, FEL
    Husqvarna XP chainsaws 346xp X3, 357xp, 562xp, 359
  6. #6
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    all i can tell you is get the tractor that best suits you.i had a kubota mx5100 hst rops 4x4 fel for 2.5yrs an loved it.it did everything i asked of it an more.but things changed on the farm an we needed a bigger tractor.so it was traded for a 7040 SU.
  7. #7
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    Quote Originally Posted by Bluegill2 View Post
    Please explain how MX5100 can have a 2 stage clutch when a single stage traction clutch and hyd pto clutch is all I can find in the parts? Thanks,Jim
    Attached Thumbnails Attached Thumbnails John Deere 5055E w/ FEL vs. Kubota MX5200 4 wheel drive with FEL-capture-jpg   John Deere 5055E w/ FEL vs. Kubota MX5200 4 wheel drive with FEL-capture-jpg
  8. #8
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Quote Originally Posted by Tx Jim View Post
    I have no idea. I just assumed the larger gear drive kubota tractors had a two stage clutch. Just like the two smaller ones I have? I have not started looking hard at the MX yet, but it is on my radar... Maybe I need to be looking at the M series?
    Don
  9. #9
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Like he would buy anything but a kubota anyway. Oh Pleeease Bluegill at least read the specs.
    Murph
  10. #10
    Join Date
    Jan 2012
    Posts
    1,870
    Success Missouri
    Quote Originally Posted by murphy1244 View Post
    Hey man, I really have been lookin at the JD 5055e and stuff...
    Don
Similar Threads
  1. John Deere 5055E
    By Kuehner Farm in forum John Deere Owning/Operating
    Last Post: 01-23-2011, 03:45 PM
  2. FEL for JD 950 2 wheel drive
    By ChoPChoP in forum Wanted Ads
    Last Post: 01-08-2011, 05:58 PM
  3. 5055E 4WD FEL
    By scrimshaw33 in forum John Deere Buying/Pricing
    Last Post: 10-12-2010, 04:43 PM
  4. 510 John Deere backhoe 2 wheel drive
    By yanmars in forum John Deere Buying/Pricing
    Last Post: 01-08-2010, 06:02 PM
  5. Hydraulics on a John Deere 5055e
    By RodneyV in forum John Deere Owning/Operating
    Last Post: 12-04-2009, 10:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
