Results 21 to 30 of 31
11-27-2013, 08:15 PM #21
11-27-2013, 08:50 PM #22
- Join Date
- Sep 2002
- Posts
- 4,278
- Location
- Red Bluff, CA
- Tractor
- Changes often!
Re: Narrowed down to 3 tractors and need factual opinions
Mahindra builds about 90% of what they sell worldwide. And since they are #1 in total sales of 80HP and down worldwide, the quantity they actually build in house is huge. That being said, in the USA they do use quite a few Mitsubishi and TYM built machines, which is the source of your comment I think. To get to #3 in the USA in 80HP and down, Mahindra needed a more diverse product line with cabs and such and have been partnering with Mitsu and TYM for quite some time now.
As for the 4025, that is a Mahindra made tractor. It is more of a smaller full size utility tractor, as opposed to a bigger compact like we often see at this HP range. Strong, simple, durable. Not for the 'bells and whistles" sort of guy. For that you would want a 4035/5035.Dave
Dave's Tractor, Inc.
Red Bluff, California
11-27-2013, 11:59 PM #23
- Join Date
- Feb 2012
- Posts
- 3
- Location
- Canfield, Ohio
- Tractor
- Massey Ferguson 1648 with a Massey DL130 Loader, Massey 1455v, NH 477 Haybine, NH 268 Hayliner, Pequea Rotary Rake 1140, Pequea Turbo Tedder TT2000, Dixie Cjopper Classic zero turn, Kubota RTV900XT, Woods BB72x 3pt rotary mower, Woods B96 mower
I owned a MF 2615 for a couple of years. I did not get the loader as I had one already. I traded it in on a 1648 with a cab and loader. I traded it in for the following reasons. It was a mistake not buying four wheel drive. It had plenty of power but not enough traction because of the lack of four wheel drive. The old style gearbox was fine, no problems there. This tractor took some time to warm up to a good operating temp. I used it mainly to operate my manure spreader during the winter and this chore did not take long enough to move the temp gage off the lower peg of the gauge. I worried about this a bit. In the summer we did the tedding and raking in our hay field the 2615 and it did fine. I would have kept the 2615 if it had four wheel drive. Also I really wanted a cab because I am too old to be on the hayfield when it is 90 degrees or in the winter at 10 degrees with a 15mph wind. Call me soft but I love the cab on my 1648. The 2615 was a heavier tractor and was very well built but all we really do is hay so my MF1455v and MF1648 do our work well. My local dealer has become a good friend and the support has been stellar. Just my two cents.
11-28-2013, 11:23 AM #24
- Join Date
- Feb 2008
- Posts
- 12,465
- Location
- somewhere usa
- Tractor
- Deere 110tlb, 4520, x749, L130
I recommend you consider a hydro transmission for your needs. I have had both gear and hydro over the last 50 years operating equipment and the hydro is the winner hands down. A gear tractor would be fine for large open field work but that isn't what you have. Most people that have used both hydro and gear tractors for small multiple use tractors prefer a hydrostatic transmission, mfwd and a fel for your work. A dozer or skidsteer might be a better choice for pushing the piles but a tractor and fel should work for small growth. I should add that I don't know of any dozers or skidsteers that are built with gear transmissions today either as all are hydrostatic.
11-28-2013, 05:36 PM #25
- Join Date
- Sep 2013
- Posts
- 17
- Location
- Hardin, Texas
- Tractor
- Mahindra 485-DI
Well after everyone saying that the hydrostatic is the way to go i will have to check more into it, but it does make sense being the most efficient for alot of back and forth movement. I may be a young man but im old school so newer technology is something im very precausious about but i will have to check into that style transmission. Thanks for that information.
11-28-2013, 06:08 PM #26
- Join Date
- Jun 2009
- Posts
- 28,182
- Location
- Branson, Mo.
- Tractor
- Kioti DK35se Hydrostat
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
11-28-2013, 09:30 PM #27
Go for the HST. I've owned both, gear has its place for sure, but HST has WAY more pros vs cons.
Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
Hustler Z Diesel 66" ZTR - JD Gator 620i
Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
12-10-2013, 12:41 AM #28
- Join Date
- Sep 2013
- Posts
- 17
- Location
- Hardin, Texas
- Tractor
- Mahindra 485-DI
Well gents I purchased a tractor a few days ago, no its not new like I was looking at but it was a deal I couldn't pass up, atleast for the rough starter work. Its a 97 mahindra 485 Di, 45up 2wd one owner 389 hours on it, 6ft brush hog and 6ft box blade $3500! Couldn't pass up that deal, what do yay think? And thanks for all the help!!
12-10-2013, 01:16 AM #29
12-10-2013, 11:19 AM #30
- Join Date
- Sep 2002
- Posts
- 4,278
- Location
- Red Bluff, CA
- Tractor
- Changes often!
That's a lot of tractor for the money, well done.
Dave
Similar Threads
anyone have opinions on Branson Tractors?
By ckm351 in forum Buying/Pricing/ComparisonsReplies: 124Last Post: 08-25-2015, 09:39 PM -
Buying Advice Changfa- Apollo Tractors, opinions
By pipingmad in forum Chinese TractorsReplies: 16Last Post: 07-11-2015, 01:35 PM -
Another newbie (to 2-wheel tractors) asking for opinions on new setup
By fclick in forum 2-Wheeled TractorsReplies: 6Last Post: 09-03-2013, 06:10 PM -
Seeking opinions on Lawn Tractors ~$2500 CAD
By Dave5264 in forum General Lawn & GardenReplies: 3Last Post: 03-29-2011, 03:53 PM -
Need opinions on some different tractors please
By mach158 in forum Kubota Buying/PricingReplies: 5Last Post: 01-24-2009, 09:43 PM
