Page 1 of 6 1234 ... LastLast
Results 1 to 10 of 56
  1. #1
    Join Date
    Sep 2012
    Posts
    51
    Burke, VA
    Scag Tiger Cat, 61", Craftsman LT1000
    Default Zero turn or tractor, 2.5 acre property
    I know this has been done to death but I'd like to get opinions based on what my property is and the associated costs for equipment. I have a little over 2.5 acres and as you can see it's mostly grass with a few trees. We've been in the house for a little over a year at this point and mowing with my hand-me-down Craftsman 42" is quite time consuming (~3.5 hours). I'm trying to decide on a zero turn or a tractor/FEL/MMM. I have a line on a used 2012 Scag Tiger Cat with a 61" deck, suspension seat and Kohler 27hp motor with ~100 hours for $6000. The tractor I'm looking at currently is the Max25 with a FEL and 60" MMM and my out the door price is $16,900 (~2500 of that is the MMM). Here's my current list of project I'd want to use the tractor for.
    Clean up brush piles/tree branches
    Remove and replace fence
    Fill in low spots in from and back yards
    Build a gravel driveway extension
    Remove 12x12' patio, replace with larger paver patio
    Lawn mowing
    Build garden
    Move large rocks from front yard
    Build whole hog BBQ pit
    Dig out area for a slab for a pole barn
    Obviously there's a lot of "wants" and not a lot of "needs" in that list but I'm wondering if that's how most of you started when you purchased your first tractor. The only real need is the lawn mowing which is why I was leaning toward the Scag but I'd like other opinions as well. The cost is another issue since the spread is about $11k. We can take the additional cost hit but it certainly would be nice to keep that $11k in the pocket. If I do buy the Scag (BTW, does $6k sound like a good deal?) I think in a couple years I'll end up getting a tractor anyway. In the mean time if anything in my list comes up I could possibly rent equipment specifically for the project. That's what I'm thinking anyway. Anyone have any opinions one way or the other?
    Thanks,
    Zero turn or tractor, 2.5 acre property-frontyard-jpgZero turn or tractor, 2.5 acre property-backyard-jpg
  2. #2
    Join Date
    Oct 2004
    Posts
    621
    Ohio
    Ferguson TO 20, Kubota B3300, BH77, Massey Ferguson 1540
    Default Re: Zero turn or tractor, 2.5 acre property
    I don't know if that is a good seal on that particular ZTR, but my vote is go with a zero turn and follow your own advice you outlined in the last paragraph..."in a couple of years...".
    When you do get a tractor you will save the $1500-2000 for a MMM and in the mean time will save a lot of your time mowing.
  3. #3
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    Beautiful property.
  4. #4
    Join Date
    May 2012
    Posts
    56
    Ohio
    Deere x500, Deere 2320
    I'll admit that's a tough one.. I might be tempted to go with a smaller end SCUT as the MAX 25 might be overkill. Maybe bx1870 or kioti cs2410. Maybe a Deere x500 or X700 series for somewhere in between on functionality.
  5. #5
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,756
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by iptman View Post
    Lawn mowing
    Build garden
    Thanks,
    I think you already answered your question. If none of your tractor projects are pressing, get a zero turn now and a few years later pick up a small SCUT something like a BX kubota should be all you need maybe with a backhoe attachment if you want to spend a few thousand more. Most folks cant justify the cost but they sure are handy when it comes time to dig a hole even if it is nothing more than to plant a shrub/ tree etc. It doesn't have to be new either by the way as long as it has been taken care of, stored inside etc one with 500+ hours is still practically new.
    As for the mower, before you buy the Scag, check out Ferris IS 700Z mowers or the Simplicity equivalent. Both have a nice coil spring and shock suspension that makes mowing much easier on the back. I got mine with the Kawasaki engine which I think is better than the Briggs & Stratton for durability.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #6
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Default
    Quote Originally Posted by bigpinwheel View Post
    Overkill is over rated. The opposite of over kill is regret. Look at (The Fred's) post on his L3940. What would you say about having an M8540 for 10 acres?
    The X700 series would not be much if any cheaper. Once you add in the cat 0 or limited cat 1 hitch neither is standard and the FEL. Which would both be required to complete the task he's suggesting. The Jd 45 loader lifts an astonishing 365 lbs to full height at the pin. While the max lifts 900 lbs.
    Small cat 1 implements will be easier to find than the cat 0 or cat 1 limited. My neighbor can't use a standard post hole digger on his toy tractor because it's limited cat 1 does not have the height.
    I think the max or even a b series not a bx kubota would be fine. For his requirements. I'm sure he could get by with something smaller like a bx or x700 but the cost difference if any probably wouldn't justify having less capability.
    I would personally go for a zero turn first but his property does not appear to have a lot of obstacles. I'm not sure what mahindra charges for a mmm but I know kubota mmm are about halfway to a descent grade zero turn.
    Regardless the zero turn would be way faster.
    Dave
  7. #7
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,654
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Amazing. Three certified tractor-holics voting for the Zero Turn mower……..
    The word tractor was taken from Medieval Latin, being the agent noun of trahere, "to pull, draw".
    Kubota B3300SU; no longer with me but still pulling in the community.
  8. #8
    Join Date
    Sep 2012
    Posts
    51
    Burke, VA
    Thanks for all the comments. Anyone else have any thoughts on the Scag and the price? I looked on tractorhouse.com and saw similar units with more hours going for $6900. My research on mowers has been limited to this site and lawnsite.com along with anything else I can find online.
  9. #9
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Why is the Scag with only 100 hours for sale?
    Murph
  10. #10
    Join Date
    Aug 2007
    Posts
    1,508
    Mid-Coast Maine
    The Scag is a good machine and I think the deck on that mower is a good one. The folks on Lawnsite would know for sure, that is a good site for learning about the +'s/-"s of a mower. The question I have.. is your lawn flat enough to handle a 61" mower without scalping the lawn. My lawn is not flat/level enough for even the 54" deck on my JD ZTR. My first reaction is that the price is fair, but you might be able to do a little better. The Ferris/Simplicity machines are reasonably priced machines that have the smoothest ride of any ZTR and cut fairly well. I have 1.5 acres to mow with more trees/obstacles than you do, and if I hurry, I can mow it in about 50 minutes. I would get the Scag now and spend more time evaluating your tractor needs/wants and your ability to rent a machine to do what you want/need for less money than buying.
    Jim
    - '01 Husqvarna W4814- 48" walk behind lawn mower.
    - '04 John Deere Z-Trac 727A- 54" ZTR
    - '13 Kioti DK40 HST - KL401 loader, DK40 72" QA bucket, LK3054 60" QA bucket, toothbar for 60" bucket, dual rear remotes, 7ft 6 way rear blade, 78" ETA Box Blade, Woods BH-90x backhoe, loaded rear tires, Kioti Canopy.
Similar Threads
  1. New 0.5 acre pond on our property
    By rogerius in forum Projects
    Last Post: 01-01-2014, 10:39 AM
  2. Buying Advice Compact for new 43 acre wooded property
    By jgoehri1 in forum Buying/Pricing/Comparisons
    Last Post: 05-20-2013, 10:48 AM
  3. Best Zero Turn for my property
    By pequeajim in forum General Lawn & Garden
    Last Post: 06-06-2012, 10:11 AM
  4. Need Help Finding Good Quality Zero-Turn for 1 Acre Property
    By yelmua in forum Buying/Pricing/Comparisons
    Last Post: 08-08-2010, 09:49 AM
  5. First Tractor Purchase for 100 Acre Property
    By ylazyy in forum John Deere Buying/Pricing
    Last Post: 10-29-2007, 04:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
