Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 41
  1. #1
    New Member
    Join Date
    Feb 2014
    Posts
    3
    Default 100 hp Utility
    In the market for a new min 85 PTO power utility tractor with cab. Have researched a bit in area and narrowed down to New Holland t4.105 JD 5100E and kubota M9960. Not an expert looking for some good advice. Will use tractor for bucket work and brush mowing ( 15' batwing) mainly. Any advice appreciated.
  2. #2
    Advertiser
    Join Date
    Feb 2014
    Posts
    83
    Honesdale PA
    Kubota
    Default Re: 100 hp Utility
    You should drive and operate each unit to see what fits your needs better.
    Each tractor is setup a little different..
    I always tell my customers to operate the machine that way they now what to expect.
    Corey Bayly - Sales
    Marshall Machinery - Honesdale, PA
    (570) 470-5203
    View Our Current Inventory - http://www.marshall-machinery.com/
  3. #3
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    look at the kubota 108 tractor.its a tad bigger than what your looking at.the frame on the jd 5100 isnt that heavy built.so you better really do some looking an thinking before you go with that tractor.plus they are about $57,000 with out the fel.an for that money if your bent on jd you can get a 6105D cab 4x4 power recerser for $54,000 with out fel an $58,000 setup for fel but no fel.
  4. #4
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,385
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Welcome to TBN. Like has been mentioned spend a lot of time test driving any tractor to get a feel, many of the features don't become comfortable till after a few hours of use.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  5. #5
    Join Date
    Jan 2008
    Posts
    715
    South
    A little of everything
    I would take a look at the NH TS6.110. It's a mid range tractor without a lot of bells, but it does have a power shuttle option. The 110 would put you at 110 engine and 90 PTO HP. From what i have seen, they are reasonably priced so you may be surprised at the tractor you can get for the money.
    It you like red better, the Farmall 110A is the same thing.
  6. #6
    New Member
    Join Date
    Feb 2014
    Posts
    3
    Default
    I am planning on lining up testing all three colors. Kind of hard to get a feel for use except for snow now. The 5100E does not show a 1000 PTO option. Mower is 1000 big spline. Will talk to NH dealer about the ts6. 110. Hoping the NH dealer is a little more flexible off their list price. Really like the specs of their machines. Going from 55 HP JD 2155 to a bit more of a tractor here. Lots to learn. Thanks for suggestions will def look into more options.
  7. #7
    Join Date
    Dec 2013
    Posts
    90
    Michigan
    2014 John deere 5085e
    Quote Originally Posted by isurat View Post
    You can get 1000 pto option on a 100e. (dealer add on) I was looking at models in the 70 to 80 horsepower range, ended up with JD85e. I dont agree the frame is light on 100e, that tractor with a cab is 8000lbs, The NH weights only a couple hundred more and the kubota is just under 7k. I was very impressed with the frame on the JD, its very comparable the JD's M series.
  8. #8
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,948
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Pretty much what others said, we have an M8540, but could have gone with New Holland, John Deere etc. The M60 Series is an improveent over the M40, so I've no experience with them. When we were looking, NH and John Deere had larger cabs and you can get an instructor seat in some, but I don't think you can in the kubota, may be important, maybe not.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  9. #9
    Platinum Member Deerherd's Avatar
    Join Date
    Apr 2012
    Posts
    994
    Upstate, NY
    LS P7030 CPS, 2016 Bobcat E42, Ferris IS3100z w/37 HP Kawasaki
    Take a look at the LS 7040CPS if you want to save some cash, but get lots of standard features. It has 97/85 HP, 40F & 20 R speeds, Power Shuttle with electronic Hi/Lo, 540/750/1000 and ground speed PTO, 3 remotes, rear wiper, stereo and a couple other things that don't come immediately to mind.
    They do have an instructor's seat shown in the owner's manual, I do have a part number and they do have them in stock but for some reason refuse to sell them! Something about liability but I'm sure if it made it past Deere's and NH lawyers, LS should have no problem. I'm not giving up yet........
  10. #10
    Join Date
    May 2012
    Posts
    154
    Blue Grass, VA
    John Deere 5203, John Deere 5083e
    I went and looked at the kubota m9960, I didn't like there build quality, you could wiggle the dash 2.5" either direction, the cab glass rattled and didn't like their transmission. I ended up getting a john deere 5083e, it is a much nicer tractor for less money, we got ours with 380 hours set up the way we wanted for $41,600. The kubota was over 50k. And for thought, the jd is not a light frame, we have ballast in all four tires and that's it no extra weight, I thing runs 9500-11000 lbs.
Similar Threads
  1. PT 100
    By WM FARMS in forum New Member Introductions
    Last Post: 09-13-2010, 12:44 AM
  2. Utility vehicle - utility vs. fun
    By Hubjeep in forum ATVs & Utility Vehicles
    Last Post: 02-20-2009, 08:18 PM
  3. Mini 4x4 utility trucks, awesome utility truck
    By Easom in forum ATVs & Utility Vehicles
    Last Post: 01-28-2008, 06:22 PM
  4. compact utility or utility tractor
    By Anonymous Poster in forum Buying/Pricing/Comparisons
    Last Post: 06-28-2002, 10:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
