Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Bronze Member Ozykioti's Avatar
    Join Date
    Mar 2012
    Posts
    74
    Victoria,Australia
    Kioti DK551C
    Default
    Dr. Emmett Brown: [reads the "Save the Clock Tower" flyer and reacts with hope] This is it! This is the answer. It says here that a bolt of lightning is going to strike the clock tower at precisely 10:04 p.m. next Saturday night! If... If we could somehow harness this lightning... channel it into the flux capacitor... it just might work. Next Saturday night, we're sending you back to the future!.............
  2. #22
    Elite Member
    Join Date
    Sep 2003
    Posts
    4,153
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
    Default Re: Logging with tractor and winch ?
    Ah well I may as well update as well! The neighbours setup was a Fransgard winch and the 65 hp tractor was actually an 85 hp (NH7740 not the 6640). He quit logging with 10,000 plus hours on the tractor.
    I too did a bunch of logging with a Farmi winch, I had a JL501 for 5 years. It was great, fantastic piece of equipment. My kubota L5030HSTC could handle 3-4 trees at a time, 60 ft tall softwoods, always pulled from the top and always working in snow. Despite the comments by Garcon the hst was never an issue, you don't use much hp logging. The winch is used at idle, and pulling logs, even with chains on you don't have enough traction to pull hard. Maybe if logging in the summer and you could get some traction, but we don't cut here unless there is snow to keep the dirt out of the bark as they are getting milled.
  3. #23
    Platinum Member gaproperty's Avatar
    Join Date
    Dec 2010
    Posts
    645
    NewBrunswick & Nova Scotia
    Kubota 4740
    Default
    I have a kubota l4740. It is 47 horse power with a Wallenstine logging winch. I also have a logging trailer. When I am skidding I can twitch out 1/3 of a cord in good going. When using my trail I usually go with 3/4 cord.
    Attached Thumbnails Attached Thumbnails Logging with tractor and winch ?-image-1789371595-jpg
  4. #24
    Join Date
    Dec 2010
    Posts
    645
    Kubota 4740
    Default
    Trying to make a road in soft soils
    [QUOTE="gaproperty;3145872"]Past years I have worked on sandy and gravel soils. No sinking no mud. Not the case now. It is a loam type soil and I sink evan when fairly dry. Some clay and lots of soft spots. I am falling smaller trees making a corduroy road. Using branches to travel on. I better get skid plate for my l4740. Anybody ever use geomaterial? Suppose to keep everything afloat and
  5. #25
    Join Date
    Jul 2014
    Posts
    155
    Clarksville, OH
    Mahindra 5035 HST w/FEL and 4-way bucket; Ford 4110
    Quote Originally Posted by Madman_Mark View Post
    What size tractor do you guys recomend for part time logging with a tractor and winch ?
    Any less then 50 HP ?
    Any advice, opinions, experiences or things to look out for etc... ?
    It isn't the Hp that really counts. It is the tractor weight. Some 50 Hp tractors weigh only about 3500 lb. Some weigh well over 5000#. A front end loader is extremely useful with 4WD not only for traction, but it helps keep the front end on the ground while winching. I wish to get a new tractor and winch myself. I once rented a bulldozer that weighed 15000#, and I had a few logs it could not pull. They were large treetops from a timber harvest. Some branches were more than 18" diameter.
  6. #26
    Join Date
    Dec 2010
    Posts
    645
    Kubota 4740
    Default
    Quote Originally Posted by Hermio View Post
    50 hp are usually heavy enough. Tire valve protectors, and skid plates could save you time and money. A fel is great to keep the tractor from rearing up.
    I know guys that used 35 hp and did pretty good with a fel, skid plate. Like the other guy said weigh does help but I say balanced weight is great to. Heavy front end with fel and 4 wheel drive keeps the tractor front wheels on the ground and steers better. Good luck.
  7. #27
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    8,796
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Even though it's a thread from the dead -
    Depends on terrain, what and how you are logging.
    Are you pulling out select hardwoods on steep slopes it's far different than clearcut 30 yr old pine.
    Most of my acreage has < 40 year old mixed hardwoods OR < 20 yr old stands of pine. For a long time I will be doing selective logging of the hardwoods.
    I figured I needed a tractor which could lift a ton on the 3pt so I could get the logs on my sawmill. That's about 10' long by 20" DBH. If you've got bigger logs you might need more power.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  8. #28
    Join Date
    Jul 2014
    Posts
    155
    Clarksville, OH
    What I hope to buy, if I can swing it: Mahindra 5035 HST, with FEL. This is 49 bare engine Hp, 4WD. With ballasted tires and no rear implement, the weight is a bit over 8400 lb. Add a winch and it might top 9000 lb. That oughta do it for most of my needs. The big timber I will still have professionally logged. I just clean up the tops and downed wood for firewood, and clear the trails. A 4 way bucket on the FEL looks like a really nice option.
  9. #29
    Join Date
    Jan 2008
    Posts
    173
    Shaftsbury VT
    Kioti DK 40s
    good luck finding a 5035 hst. I'd give my left leg to find one now
    Kioti DK 40S, with a Farmi and Tractor Forks!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
