tman1020
- Joined
- Jan 16, 2014
- Messages
- 1,467
- Location
- north west indiana
- Tractor
- Bobcat ct225 and Bad Boy zero turn
About your hour concern. If you are using it for mowing 3 acres you are going to rack up the hours faster also. I chose to keep the hours on a less expensive zero turn plus I feel it is better designed for the job. No one knows for sure how many is too many all depends on individual tractor and use however in my opinion I like to think that 4000 hours is a safe bet for most compact tractors. Many will go much more many will go less just all depends on many factors; use maintenance build quality etc. but that's what I use as a baseline. One thing for sure that Yanmar engine should be very good Look up as many threads and reviews on both as you can I have not seen a lot of problems on the bobcats. As I also was looking at both of these tractors before I purchased. I did however read a lot of things on the JD that I was a little uncomfortable with however I believe they sold more of them.
