Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Jun 2014
    Posts
    101
    SC PA
    Garden Tractor
    Default Difference Between 4WD and MFWD ?
    It's probably been asked before, but, what is the difference between 4WD and MFWD ? Is one better than the other or have advantages ? Is one typically more expensive ? How about maintenance & repair, problems, etc. ?
    Appreciate any education you could provide me.
    John
  2. #2
    Super Star Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    15,671
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Difference Between 4WD and MFWD ?
    I will take a crack at it and see what others say. 4WD, may or may not be "mechanical" as in MFWD (Mechanical Front Wheel Drive). Some front drive system are hydraulic with hydraulic motors on the front, not drive shafts, U joints, and differentials. Also some mechanical systems are not really designed to be full time 4wd system, but to only be used to assist the main rear drive, and are called MFWA as in "Mechanical Front Wheel Assist". Most CUT sized tractors are going to be Mechanical in nature, in other words, drive shafts, and such, not hydraulic, and are going to be considered "assist" not full time systems...One thing to note is the tires on most CUTS are much smaller on the front than the back, and do not have the pulling power that the rear tires do.
    Others may argue some or all of these points, but that is what I think.
    James KUA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  3. #3
    Join Date
    Oct 2008
    Posts
    768
    Piedmont Triad, NC
    Didn't intend to have a Deere fleet - it just happened 310C, F915 & 5200
    In the ag world, A 4WD is an articulated tractor... That is it steers by bending in the middle. A MFWD is a tractor that steers the front wheels while driving them.
  4. #4
    Platinum Member ModMech's Avatar
    Join Date
    Dec 2009
    Posts
    652
    Canton, TX
    Kubota B2410
    ^^^ What he said, or "4 WD" can also refer to a "2 WD" tractor with 4 rear tires, but that's not common.
    JohnG
    We have Democracy, but were founded on Liberty.
    Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote - Benjamin Franklin (1706-1790).
    I am for LIBERTY!
    I Support electric trailer brakes on EVERY axle over the towing vehicle's GVW, CDLs for RVers and safety inspections on ALL licensed vehicles!
  5. #5
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    1,486
    Northeastern Minnesota
    JD 7720; Kubota M135GX, NH TS115A; JD 6230; Kubota L5740
    Default
    What Hossworld said - 4wd in ag refers to large articulated. MFWD is Mechanical Front Wheel Drive - like an old time 2 WD tractor with mechanical front wheel drive that can be engaged or not engaged. The 4wd tractors have the articulation joint in the exact center so there is no differential needed between front and rear. Consequently front and rear tires are the same size. MFWD is typically disengaged for highway travel. Our John Deere and New Holland tractors have an auto position on their MFWD. When the tractor reaches a certain ground speed the front wheels are automatically disengaged - assumption is the tractor is being roadbed. If the brakes are engaged the MFWD is automatically engaged to reduce stopping distance.
    JD7720; KubotaM135GX; NH TS115A; JD6230; KubotaL5740
  6. #6
    Join Date
    Jun 2014
    Posts
    101
    SC PA
    Garden Tractor
    Quote Originally Posted by MHarryE View Post
    Thank you for your response...however, I'm still unclear...must be me. I have an old Ford truck that I can lock out the front hubs and engage 4WD. I know some Ford's are equipped with hydraulics that enable one to shift on the fly from inside the cab. Is this anything like that ?
    On tractors, is the MFWD more desirable or advantageous over what I'll call full-time 4WD ?
    Sorry about my inability to grasp things. I appreciate your patience.
    John
  7. #7
    Elite Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    4,703
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    You're confusing apples/oranges. Your furd truck has the ability to engage the front axle to make all 4 wheels pull when the front hubs are engaged, locked IN, not locked out. When unlocked the truck is rear wheel drive only. In the cab is a button that actuates 4wd electrically, instead of manual hub turning at the front wheels.
    The posters were talking about articulating tractors which are pinned in the middle of the chassis/frame and allow all four wheels to turn, and the tractor front 1/2 can and does turn at the pivot point instead of the entire tractor following the front wheels in a straight line, therefore a more flexible turning radius, and all four wheels are independently turning and pulling at the same time. More traction, more maneuverability, etc. And they mentioned mechanical 4wd uses axles, differentials, etc. like your truck.
    2010 DK-40se/hst, Kioti KL-401 FEL, (reversible Kioti cutting edge), 72" Ratchet Rake. Fit Rite Top-N-Tilt hydraulics & diverter valve. HLA Series 2000 7' snowplow, Aquiline MPC rear chains. Samuri Sickle bar.
    Scag Wildcat: Kawasaki 26HP, with bagger. Dr. brush mower, & 42" lawn deck, Dr. self propelled, 6.5HP Trimmer mower. Pro-Mow 3 gang mower, no HP.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss, '86 anniversary edition.
  8. #8
    Elite Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    4,854
    North Texas
    JD 4255/Kubota M7040 HDC
    Back in the heyday of large 4WD tractors besides articulated models that pivoted in the center some manufacturers built "crab steering" where both frt & rear wheels steered similar to MFWD frt axle.
  9. #9
    Member
    Join Date
    May 2014
    Posts
    39
    Somewhere, OH
    John Deere X748 Ultimate
    Quote Originally Posted by bigcut View Post
    John
    bigcut, your profile says Garden Tractor. I too have a garden tractor. A John Deere X748 with HFWD (Hydrostatic Front Wheel Drive). There were previous models of the X700 series that had MFWD (Mechanical Front Wheel Drive). The difference is a MFWD has a mechanical drive shaft from the rear trans axle to the front axle. The front axle contains a traditional differential and transfer case all mechanically linked to the rear hydro static trans-axle where the power is generated.
    A HFWD's front axle is actually two variable displacement hydrostatic motors where the fluid for the motors comes from the hydro static pump in the rear trans axle. There is no mechanical connection between the front and rear axles.
  10. #10
    Join Date
    Jun 2014
    Posts
    101
    SC PA
    Garden Tractor
    Thanks ber,
    I now understand what HFWD is....but must confess my understanding is still unclear on my original post. Thanks,
    John
Similar Threads
  1. mfwd vs 4wd
    By Anonymous Poster in forum Buying/Pricing/Comparisons
    Last Post: 04-22-2011, 11:59 PM
  2. 4wd vs mfwd
    By rustedduck in forum Buying/Pricing/Comparisons
    Last Post: 07-08-2008, 01:15 AM
  3. FWD vs. MFWD - What's the difference? Which is better, and why?
    By ArtVandelay in forum Buying/Pricing/Comparisons
    Last Post: 07-05-2007, 06:20 PM
  4. Difference between 4WD and MFWD
    By hayden in forum Buying/Pricing/Comparisons
    Last Post: 10-30-2006, 11:22 AM
  5. What's the difference between a 4500 4WD and 4530
    By Latheman in forum Mahindra Owning/Operating
    Last Post: 08-05-2005, 12:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
