Poopdeck Pappy
Elite Member
- Joined
- May 13, 2013
- Messages
- 2,629
- Location
- Dallas, Texas
- Tractor
- Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
That does make sense on what year.
Sorry I did not make sense on my reply(stupid iPhone) what the neighbors all do is till up around the shelter belts not mow like I'm hoping to do.
Good point on taking a few off if it's to hard to pull. The disc is nearly straight and welded that way so I guess that's what I got.
Thanks for the input the tractor field is so confusing to me.
I understand the confusion. It can be VERY confusing. For your situation, I'd suggest the 90/10 rule. I.e., figure out what you need for 90% of the time, and then figure out how to use that machine to get the other 10% done.
It sounds to me like you need a 50hp tractor about 90% of the time, and a 70 or 75hp tractor about 10% of the time. If you've got plenty in your budget, then I'd buy a 75hp tractor with a hydraulic shuttle transmission, which is not as easy to use as HST, but it's easier than a regular shuttle or a standard old gear tractor. (With the hydraulic shuttle, you still have gears and you have a lever on the steering column to change from forwards to backwards, and you don't have to use the clutch to change directions.) Unfortunately HST transmissions are not available on tractors over approx 60hp.
If 60hp will do it, then a Kubota L6060 or L5740 would be a good fit, and both are available with an HST tranny. The Mahindra 6010 and Kioti NX6010 are also available with HST. I'm not sure what the other manufacturers have in that range.
I'd suggest going to your local dealers and do some test drives and get their recommendations also.
