Roger66
I'm 99% sure I'm buying a Mahendra 1526HST tractor this year. I'm am still open to other options, but I haven't found any others that compare with the price and specs I'm interested in. The particular specs I'm looking at is Bucket lift weight and 3 Point Lift weight. Still trying to fund the initiative so I'm still in the research phase. I posted another thread and no one had anything bad to say about this tractor and I've been researching this to death! For this question forget brand and lets talk Horse Power. Obviously this answer is different for different users. My use is primarily lugging. Towing, lifting, moving. I'll likely get a 60" rear snow thrower, a PTO chipper and a Post hole digger some day, but no mowing or brush hogging. If my research and understanding of it is correct, for lugging I should be totally fine with a 25 HP tractor. It's the PTO use that causes the need for more HP. Wide mowers and brush hogs (which I don't want or need) seem to cause the need for over 25 HP. I'm sure it's obvious why I prefer not to cross the 26HP line in the sand, but I don't want to pay for and maintain the Tier 4 emissions equipment. I only have 1.5 ache's of land so It's hard enough to justify this purchase, I really don't want to cross the 20K threshold. The PTO Chipper pushes the limit for 25 HP, but I burn firewood. Larger branches are good firewood for me, so I won't be chipping massive branches, just the stuff too small to log up. The worst thing would be if I hooked up one of my heavy trailers pressed the HST pedal in low range and didn't move because I did't buy enough HP! I hope I would loose traction before I ran out of power. What do you guys think?
Thanks!
Thanks!
