Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    New Member
    Join Date
    Apr 2016
    Posts
    17
    Nichols, sc
    none
    Default Lookin' For New tractor 36 Acres (Open to Suggestion)
    I have a total of about 36 acres of land; 10 acres of ~4' tall bush land, 24 acres of woodland, and ~2 acres of roads.
    Jobs To Do:
    -Mow high brush and saplings ~2in
    -maintain 2 roads (some areas are Gravel||Clay||Sand or combinations there of)
    -cleanup land debris (hauling logs and branches)
    -cleanup trash (light construction debris, concrete sidewalks left on property from fallen builds)***
    -dig up septic line, dig footings, level land for new construction, and maintain ditches
    -Move Large amounts of dirt/clay/sand
    Things I'm looking for are Front loader, Backhoe, Box Blade, Rotary Cutter, Root Grapple at the least.
    Later job would include, moving pallets, tilling, plowing, posthole digging, wood chipping and spiting.
    I'am trying to keep total costs around $50,000; I looking for suggestions on a tractor capable of most if not all these task to some degree. Due to the kid in me I keep looking at really large HP tractors that are out of the budget. I don't want to go to small and end up stressing or breaking this tractor either.
    *** if it cant do this I'll have to rent something later on, so this isn't critical.
  2. #2
    Elite Member Luke'sScreenName's Avatar
    Join Date
    Mar 2015
    Posts
    2,653
    Lakes Region, NH
    Kubota MX4800; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
    Default Re: Lookin' For New tractor 36 Acres (Open to Suggestion)
    Cab or no cab?
    My wife told me to grow up. I told her to get out of my fort!
    -There's NO POINT trying to educate someone who already knows everything.
    -Many people don't know the difference between their opinion and fact.
  3. #3
    New Member
    Join Date
    Apr 2016
    Posts
    17
    Nichols, sc
    none
    A cab is a Plus and I would love to have it; but if it comes down to it I'll live without it.
  4. #4
    Platinum Member grm61's Avatar
    Join Date
    Apr 2009
    Posts
    810
    Eastern Washington
    2013 Kioti DK45SE HST Cab
    You are going to plunk down some money, better to get what you want first time around, the factory cabs are a bargain IMO.
    40 to 55 horse frame size would serve you well...I believe they are making some 40 horse tractors now in the smaller frame size, used to be 30/35 horse...get some thing as big as my DK45SE HST, good loader capacity, and enough weight with the rears filled to get some work done.
    I leave the Hoe on mine most of the time except for winter, loaded tires, plus the hoe, it is pretty capable.
    2013 Kioti DK45SE HST Cab, Loaded R4s, KL401 Loader with reversible cutting edge, KB2485 Backhoe with Mechanical Thumb
  5. #5
    Join Date
    May 2016
    Posts
    944
    near Roanoke VA
    584 IH 4WD
    If you are not POSITIVE what you want,,, do not buy new first,,,
    The first tractor you buy is ALWAYS the wrong one.
    The second or third is pretty much perfect.
    I just bought my 4th bigger tractor,, that is over 35 years.
    The first one was gas, 40HP, I had it ten years,
    I might have still been suffering with it,, but,
    I ran into a great deal on a diesel.
    My fourth,, I just purchased,, is a 40HP,, but, diesel,,,
    it is pretty much perfect.
    After all that time, I have never purchased new.
    I have 40 acres.
    Some of the tractors include JD 4105, JD 855, JD 650,,,, and,,, the IH 584 4WD
    My favorite attachment is the homemade landplane,,, EVERYONE needs one of those!!
  6. #6
    Join Date
    Apr 2009
    Posts
    810
    Eastern Washington
    Quote Originally Posted by CADplans View Post
    I have 40 acres.
    If you do enough research that does not need to be the case
    I found my first tractor to be EXACTLY what I wanted..I ordered it that way.
    Biggest mistake folks make is not buying enough tractor the first time, and not getting a cab first go around, when that is what the really wanted...do a lot of pissing into the wind before they get it right
  7. #7
    Join Date
    Dec 2016
    Posts
    62
    Chelsea, AL
    none yet
    Mahindra 3550 would be perfect for you. I have about 35 acres that I'll be doing the same thing will be and this tractor is my choice.
    Lookin' For New tractor 36 Acres (Open to Suggestion)-img_3338-jpg
  8. #8
    Super Member
    Join Date
    Jan 2011
    Posts
    5,314
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds
    Here is a Cat you may find interesting: Caterpillar 416 Cat Backhoe Front End Loader with Cab | eBay
    Here is a TYM/Korean you may wish to consider: New TYM Cabin Tractor and Skid Steer Loader | eBay
    I have no idea about TYM service in S.C.
  9. #9
    Platinum Member MF283's Avatar
    Join Date
    May 2009
    Posts
    704
    Lebanon, TN
    JD 5303 JD 920M JD825I XUV Gator
    I have 35 acres with just around 7 of it in woods, the rest is open. In the 30+ years I've had the place, i'm on my 4th tractor, started with a 32 HP(gas), went to a 35 HP(diesel) onto a 80 HP (diesel) & now have a 60 HP(DIESEL). All these machines were low hour used when I bought & sold them, made money on the first one & sold the next two for what I paid for them.
    I got a great deal on the last one, 4 year old with 165 hours on it, have ran it 6 years & have been offered what I paid for it. I agree on the 50 HP range for what you're doing, small enough for tighter spaces & big enough for better sized implement's.
    Good luck with your search.
    Ronnie
    Haven't seen to many tractors i didn't like, just partial to Deeres.
  10. #10
    Join Date
    Mar 2015
    Posts
    2,653
    Lakes Region, NH
    I agree, you need a large CUT in the 45-60 hp range. Keep in mind that people will usually suggest what they know which is what they own. Honest opinions, just quite biased. With that said...
    Look at the Grand L series of kubota (Lxx60). Especially the L6060. GENERALLY considered to be the best/nicest large CUT on the market (just not the cheapest).
Similar Threads
  1. Replies: 59
    Last Post: 10-04-2013, 12:44 PM
  2. Tractor Suggestion 3 acres Lawn 5 acres Field
    By dpcote in forum John Deere Buying/Pricing
    Last Post: 06-01-2012, 09:34 AM
  3. Suggestion for 16 acres
    By jkruer01 in forum Buying/Pricing/Comparisons
    Last Post: 11-13-2006, 09:10 AM
  4. What tractor for 3.5 open hilly snowy acres....
    By DCJL in forum New Holland Buying/Pricing
    Last Post: 06-26-2005, 02:49 PM
  5. Newbie Lookin' for a Tractor
    By TxSam in forum Kubota Buying/Pricing
    Last Post: 11-09-2001, 09:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
