IndianaGuy
Hello,
I have been looking at buying a tractor for about a year and have done my research but wanted to consult with actual tractor owners first. I own 5 acres, that is primarily wooded, with a creek and an open meadow that has a high water table. Water collects in old skid steer ruts. Frogs etc. It does dry up in summer though. Creek divided property into two. Back acreage has a ridge but then flattens out. Pictures attached of meadow.
My goals/expectations for use are to:
1) Move firewood, pulling logs to firewood process area
2) Mow the meadow with a rotary cutter
3) Till 1/2 acre and plant buckwheat for my bees
4) Have a pond dug (rent excavator OR hire out) and use tractor to move dirt
5) Move mulch (25 -30 yds a year), ripp rapp, balled/burlap trees.
6) Make a bridge to access back half of property. Probably use steel beams to support tractor weight.
7) tow log splitter and chipper around
Lets get to the tractors. All hydros. I've been reading threads here on and off for a year and I took the time to go through all of the archives regarding each tractor and "5 acres".
1) Kubota B2650. Its light so moving wood through the meadow and mowing the meadow wont create more ruts. I've read that you should move up one size tractor and my initial choice was a B2601. It has good hydraulics, good FEL lift capacity and some niceties such as tilt steering and floor mats. It fits in the 3rd bay of my 3 car garage too (no pole barn or external garage). It seems like the best size for my forested property and somewhat wet areas, which do actually dry up in late summer. 3 Kubota dealers all within 15 miles or so, which will be nice if warranty claim or service.
2) Kioti CK2610. Heavier. Might tear up meadow more but more stable? and better FEL lift (~1250). Wont have to buy as heavy rear ballast when lifting trees or heavy objects. Will have to put ROPS at 45 degree angle to get into garage.
3) I've demoed the L2501 and found the CK2610 to be a little nicer, with more FEL lift so figured if I went heavier than a B2650 I would go Kioti. Not opposed to L2501 but just like the 2610 better.
4) Interesting option here. About 2 hours from me sits (2) Kioti Ck30s and (2) Kioti Ck35s. Both new. I am a little leary that dealer is too far away but the tractors have been on lot for awhile so maybe I could low ball them and see what happens? CKs have tilt steering, 3 inches shorter than CK10s and no DPF.
I actually just bought forks from Everything Attachments as they're 200lbs vs the 300lbs that Land Pride produces. Figured I could allocate more FEL lift this way. (I guess I am have to buy a tractor now:laughing
Also need box blade, ratchet rake, and RC.
B2650 w/ FEL (60 inch bucket, forks, 4' RC, BB, quick hitch and filled tires: about 19k before tax
CK2610 with same setup but 5 foot cutter is $20,600 before taxes
L2501 " " ~20k
CK30 with FEL: They're asking $20,500 0% on 60 mos. No attachments
CK35 w FEL: Theyre asking $21,900 w 0% on 60mos. No attachments.
THANK YOU for any advice, info, thoughts etc.
L2501 " " ~20k
