Vas
I'm looking for tractor recommendations for use on 29 acres at 9,000 ft in Northern New Mexico. The extent of my knowledge is from reading TBN for a couple months and reading part of Muhammed's book. I mention the altitude as I've read another thread discussing 3% loss of hp per 1000ft, and 1% loss w/ turbo.
At the risk of providing too much information here are the particulars. The property is steep and fairly rocky, 20 acres are overgrown mixed conifer forest with some aspens thrown in, 9 acres are meadows. The access roads are steep and rocky (see picture). I'm looking for a tractor for small road making and road maintaining tasks like smoothing, cutting, grading, and plowing. I've been doing a lot of thinning and would like a tractor to help skidding, moving, and lifting logs. During mud season or heavy snows I would see using it (while pulling a trailer) for transport into the property. The roads are steep and rough enough I would also like to use the tractor for moving myself and equipment around the property. Lastly, I'm thinking eventually I would do dirt work associated with building a home (I'm not sure if the amount of dirt work will justify a BH). A lot of folks here need to do mowing or brush cutting, I don't need to mow or brush cut.
This is a 2nd property that I will mainly be working on during the weekends and eventually building a home, my current home is 3hrs drive away. I currently have a 40' storage unit for storing equipment. Anything I buy would ideally fit in the 8'x8' door. There are so many big trees I'm initially thinking of building a home-built log cabin. Currently I access the upper meadows in my small nissan pick-up. Every time I do it to haul up equipment for camping and thinning the forest I realize it is too rough and steep (see attachment) to continually drive up and I need to do something better. My current thinking is building a garage at the bottom and ideally using the same tractor to access the upper meadows pulling up an equipment trailer. At this point the property is a hobby, so I'm enjoying doing a lot of the work myself. That being said as I look to buy a tractor if I'm thinking I will do things where I should really be hiring a professional people's advice would be appreciated. Thank you in advance,
