</font><font color="blue" class="small">( I've just purchased a 5 acre property that is almost all in closely cropped grass, so i need a really good finish mower. I also have alot of projects that i would like to do that would require a post-hole digging attchment and maybe a scoop on the front , so i guess i need something with a pto. I know that kubota has some compact tractors, that are also belly-mowers, but i wonder if that versatility would come at the expense of effecient mowing. it seem that for pure mowing it would be hard to beat one of those big zero-turn mowers, but i don't see any of those with a pto? Any one been down this road before? thanks for the feedback.
rory )</font>
ZTR mowers mow fast because they are very manuverable, not because their ground speed is really any faster than a tractor. The larger the tractor the slower the mowing will be if you have landscaping, buildings or other obstructions to mow around. I would want a 72" mower deck.
My preference is much like the advice given to you by ronjhall in the very first reply to this thread. A small, light, tight turning tractor, that has high PTO horsepower and a 72" Mid-Mount Mower will be the fastest mowing tractor I can think of. MMM are faster to use around landscaping, amonst trees, and around flower beds. A Rear Finish Mower is certainly a less expensive option, but as I've owned both types, I think that if there is a lot of landscaping the MMM is a better choice, especially for anyone new to tractors as they don't 'gator tail' and hit things unintentionally like a RFM is prone to do. I also strongly prefer a lightweight tractor for mowing, it tends to cause less turf damage and rutting than a heavy tractor. As Ron suggested, I would also suggest the compact, lightweight, high horsepower B7800 or B3030 from Kubota. I would also suggest you learn how to remove the Front Loader, they have a quick attach system, and any tractor with the FEL removed will be much easier to steer around your wife's prized rose bushes.
As for gang/reel mowers, you need to have a smooth lawn to utilize those effectively. As has been previously mentioned, think in terms of a golf course. If your lawn is rutted, pocked with holes, or even just lumpy and bumpy, then a set of reel mowers is not going to work well for you.
