patrick_g
Elite Member
wolc123, I don't want to start a fight but I do want to say something based on over 5 years experience using a HD box blade with hydraulic scarifiers, a HD 6 ft brush hog taking down trees up to 4-6 inches in dia, the HD FEL with bucket, pallet forks (1300 lb cap), and hay spike (handling round bales over 1000 Lb). I also have various dirt working tools like tiller, sub soiler, middle buster, disks, PHD, angle blade, etc.
I work the tractor hard, like recently when repairing some erosion damage for a friend who was helping me log some big cedars on his place where I followed my usual method which is to first fill the bucket and then the box blade to carry two loads to the depression I am filling. This is quite a load and sometimes at full throttle in low range, especially up grade, the tractor just can't go any more and I have to ease up on the down pressure on the box blade to be able to make forward progress.
I have done this with A/C and with it switched off. The difference in HP required to do the hard work and the A/C requirement is so great that turning off the A/C makes no noticeable difference in the "stall point." I'm sure a sensitive dyno can measure it as the A/C takes a a few HP but in my experience once you get that close to the edge of the envelope you need to lighten up on demand by way more than the A/C uses.
In lower power units the effect would be greater as max HP was less and A/C takes a larger percent of available HP but at 39.5 HP on my Kubota I haven't found A/C to limit my work output noticeably.
I can't say what would happen with a JD, or a brand X tractor but with my 39.5 HP Kubota the A/C is not a major limiting factor. As for needing 50 HP to run A/C and HST??? Maybe with some brands or models but not for the Kubota L-4610HSTC.
As to the need for a lot more HP to run the HST... My Kubota is 39.5 HP with HST and the geared model is 40 HP. It is possible (but unlikely with GOOD brands) that other tractors lose much more power in the HST or have less efficient A/C that requires significantly more HP but again, probably not in the NAME brands.
Of course for a specific task like running a baler that is over sized for the tractor when you are at the edge of the envelope ANY extra power requirement could be the straw that breaks the camel's back. Can't comment on how frequently it happens that an implement takes ALL available HP and any extra load stops progress and there isn't any way to ameliorate the situation.
Pat
Pat
