Results 1 to 9 of 9
  1. #1
    Bronze Member koop's Avatar
    Join Date
    May 2007
    Posts
    60
    Madison Virginia
    Case IH 495
    Default 3 Point Hitch Problems?
    I have a 1991 495 4WD with 1068 hours. When off, the hitch will steadily drop until it rests on the ground. The New Holland dealer I purchased the tractor from (with about 1040 hours) swore this was not something to be concerned about. I took him at his word until recently I attached a scraper blade and found the only way to raise it fully was to set the draft as light as possible. The hitch seems to pulse as it tries to keep the implement fully raised. This is my first tractor so I am unsure of what is normal behavior. Any advice would be appreciated. Thanks
  2. #2
    Join Date
    Jan 2007
    Posts
    604
    Manhattan, Kansas
    NH TC45D
    Default Re: 3 Point Hitch Problems?
    It sounds like a cylinder rework is in order. Dealers will say almost anything ambiguous to sell a tractor.
    I would approach him about repairing it(since the statement that it wasn't a problem is, in my view, a statement of warranty), but not get my hopes up.
    Chris
  3. #3
    Gold Member
    Join Date
    May 2007
    Posts
    471
    well lucky you i just bought a mitsubishi and the lift will not go up.i am trying everything that the seller tells me still it does not work.it has fluid and the pump works. fluid is jd20.
  4. #4
    Elite Member JC-jetro's Avatar
    Join Date
    Jul 2006
    Posts
    3,284
    Kansas
    Ford 1700, Kubota MX-4700
    Please refer to one of my posts earlier on. It will include almost all the problems that can be attributed to 3 point lift failure with detailed pics. The basics are the same no matter what brand.
    http://www.tractorbynet.com/forums/n...-my-first.html
    Ford 1700, 2wd.
    Kubota MX-4700DT, Gear transmission with LA 884 loader, Q/A and HD bucket.
    60" Woods Rotary Cutter, home made (3-pt boom and a Row Hipper) ,King Kutter( 5 ft Tiller,Middle Buster,Single Row Cultivator,Carry-all, 5 ft blade, 6 ft Landscaping Rake ,30" Dirt Scoop and a 4'x4' Drag Harrow)
  5. #5
    Join Date
    May 2007
    Posts
    60
    Madison Virginia
    Case IH 495
    Thank you for all the helpful info.
    Does the fact the hitch drops when the tractor is off indicate a leak in the system or do some hydraulic systems just naturally drop when not pressurized?
  6. #6
    Join Date
    Jul 2006
    Posts
    3,284
    Kansas
    Quote Originally Posted by koop
    Yes, It is a leak of some sort, either internal or external. External leaks leave a tell tale sign that you can find a source. If it is internal then by process of elimination you can find a source. If your control spool valve, some relief valve main or lift cylinder leaks then pressure can not be maintained and the lift will drop due to it's weight. Saying all of that it seems 9 out of 10 is the lift cylinder ring/seal (usually Nylon made) that fails. There is a simple affective method than you can almost eliminate that possibility. the test is simple and needs no tear down. almost all 3 pt lift system have a rate of drop needle valve and knob right under the tractor seat. When the spool valve is set to drop the 3 pt lift the trapped hyd oil returns thru this orifice back to the oil reservoir. By adjusting the needle valve in or our you can reduce or increase the rate of how fast the fluid passes the valve. All you need is to lift the cylinder as high as you can and reduce the rate of return to zero, effectively closing the return passage, if the arm drop then you have 99% chance the piston seal is not holding tight. I would do that test before anything else. Good luck.
    lift cylinder head, piston and cylinder:
    Cylinder head, the hole in the middle has the rate of drop needle valve:
    Lift system with rate of drop knob on the cylinder head.
    Ford 1700, 2wd.
  7. #7
    Veteran Member daTeacha's Avatar
    Join Date
    Oct 2005
    Posts
    2,352
    Funk, Ohio
    Next time he tells you it isn't a problem ask him to lie on the ground with his neck under the edge of a heavy rear blade to watch it. Then shut the tractor off and see how long he stays there.
    Rich
    300 hours on the DX29, 850 on the JD 240 and too many to count on the Cadet
    Funk, Ohio
  8. #8
    Join Date
    Jan 2007
    Posts
    604
    Manhattan, Kansas
    NH TC45D
    When I was growing up with farm tractors, the 3-point would hold for months, even with 2000 lb loads on them. The 3-point on my tc45 nh will hold a tiller for over a week(that is as long as it has been there).
    That isn't normal, but is predictable for older tractors, or ones with dirty oil. A little flaw at 2500 psi will leak a significant amount of oil.
    The advice listed in the tag above is good:
    relief valve leakage
    o-ring leakage
    control valve contamination
    pump(not as likely if your fel works)
    Chris
  9. #9
    Join Date
    May 2007
    Posts
    60
    Madison Virginia
    Case IH 495
    Quote Originally Posted by daTeacha
    Thanks for the laugh, I start my negotiation with Jamie with that!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
