Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Jun 2010
    Posts
    2
    Default HOW DOES A IH-MCCORMICK HAY RAKE NO.15 WORK
    I have obtained an old IH-McCormick hay rake, model number 15. It is different then some of the old fluffers and hay rake I have used in the past.
    What are the adjusting screw for? Some previous owner had welded stops on them.
    How much tension should there be to engage and disengage the real from the driver? Some previous owner has used air craft cable and ran it from the leaver to the front end of the rake.
    There is a hardwood tension block attached near the left front drive wheel. I am assuming that there was an idler gear and adjustment for the chain and someone has cut the gear off and shorten the chain to the point the tension block is not needed.
    I believe that the rake was manufactured around 1957. This was determined from a document that discusses the color scheme for the rake.
    Any input would be greatly appreciated.
  2. #2
    Join Date
    Jan 2010
    Posts
    67
    Dunvegan, Ontario, Canada
    Default Re: HOW DOES A IH-MCCORMICK HAY RAKE NO.15 WORK
    Hi....I think I may have the same model of hay rake....not sure the model number is worn off. The two screws on top are used to lower and raise (adjust) the hieght of the tines. The cable is for engaging and disengaging the gear box that turns the bars with the tines.(I think the cable just hangs slack when gears are engaed.) The cable is OME. The hardwood block is also correct.....it acts to keep the chain tension correct. Hope this helps......sorry for some of the poor terminology but I've never found a manual.
    If left outside for long periods of time my gear box does get water in it (this can present many problems eg. freezing and cracking gearbox.
    Casey
  3. #3
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,850
    central New York
    all makes and models
    The model 16 has a few differences and is easier to find. You are correct and we do see some of the modifications we have seen.
  4. #4
    New Member
    Join Date
    Apr 2012
    Posts
    1
    Tunkhannock, PA
    JD 3020
    Hi, If you have a McCormock International Harvester model 15 rake, it has five bars, is chain driven, has a gearbox on its left side, and there are two round holes in the frame. My model number rubbed off too and I need to find a parts manual for it.
  5. #5
    Member pitotshock's Avatar
    Join Date
    Oct 2006
    Posts
    27
    Renfrew, ON, Canada
    Case 885XL, Kubota L355SS, Kubota M7050
    Henry,
    Any luck finding a parts manual for this one?
    The CaseIH publications site has the Owners Manual ($5) and the Service Manual ($7) available for download, but no parts manual. Anyone have a copy?
    There is more to life than that blue glow of the television. Get outdoors and experience it!
Similar Threads
  1. McCormick "Farmall" tractors
    By Anonymous Poster in forum McCormick
    Last Post: 08-08-2011, 08:24 PM
  2. DK45S Cab & Kuhn Hay Rake
    By Hoosier Hay Man in forum Kioti Owning/Operating
    Last Post: 04-25-2010, 09:14 AM
  3. Rake Question on hay rake size
    By drw in forum Attachments
    Last Post: 12-20-2008, 08:49 AM
  4. hay rake repair
    By chicken991 in forum Parts/Repairs
    Last Post: 10-31-2008, 04:16 PM
  5. Need to transport baler, grain drill, hay rake
    By flusher in forum Trailers & Transportation
    Last Post: 03-28-2008, 03:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
