Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    11
    Louisiana
    Default Adjusting clutch
    I have recently come to own a 1989 Case IH 385. I am confused in looking at Operator's Manual as to how or even if the clutch needs to be adjusted. The manual states to lift up on the clutch pedal and if lift is less than an inch then adjust to various measurements. Does this mean to lift from the at rest position? Or the amount of lift before the tractor moves when in gear? My concern is that the travel in the pedal from rest to engaged is a long press. Also the tractor moves only when I am on the last inch or so from the top. I noticed that the safety swith is backed almost all of the way back so the pedal has to be at the bottom of cycle before switch is engaged.
  2. #2
    Join Date
    Jun 2000
    Posts
    778
    Central Mississippi, USA
    Case-International 385, Kubota L5450 w/LA1150A loader
    Default Re: Adjusting clutch
    I have a 385. I think the 1 inch lift is referring to lifting it from the rest position. As your clutch plate wears, the pedal will rise because the throwout bearing runs on the clutch fingers all the time. I think the easiest way to get the adjustment is to measure the pedal height to the footrest (6 5/16"). I didn't like the idea of the constant contact throwout bearing so I made a modification to get free play in the clutch linkage. Hopefully a picture is attached.
    Attached Thumbnails Attached Thumbnails Adjusting clutch-clutchsmall-jpg
Similar Threads
  1. Clutch Life Expecancy in Hours
    By mrlullabye in forum Owning/Operating
    Last Post: 06-22-2013, 05:25 PM
  2. We are in a clutch ...
    By Qapla in forum Parts/Repairs
    Last Post: 09-08-2009, 05:47 AM
  3. Why use clutch with GST?
    By Jay4200 in forum Kubota Owning/Operating
    Last Post: 10-09-2006, 01:32 PM
  4. Dealer Big Dealer Problem - Replacement Clutch - help
    By MikeLonghurst in forum Chinese Tractors
    Last Post: 03-09-2006, 06:57 AM
  5. Adjusting a Tiller driveline slip clutch
    By LGinIA in forum Parts/Repairs
    Last Post: 02-23-2005, 09:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
