Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Mar 2011
    Posts
    7
    IH 424
    Default 424 Parking brake
    I just received the parking brake assembly which was missing when I bought this 424 Diesel. I'm having a hard time figuring out how to attach the spring to the lever. All pictures I've seen show the level straight up and down and the broken lower part of the lever had the teeth facing forward. And I believe the teeth should be facing forward due to the placement of the part the teeth catch on which is attached to the inside brake pedal arm. I further assume that the spring is supposed to keep the lower part of the parking brake lever to the rear (away from the catching mechanism) to keep the parking brake from engaging every time the brake pedal is pushed in. (Hope you guys aren't as confused as I sound.) My problem is the only way I can figure to attach the spring has it pulling the lower part of the brake lever forward to the engaged position. Anybody out there have a 424 with a working parking brake and a digital camera who could post a photo of this assembly? The owners manual doesn't help either.
    Many thanks,
    Randy
  2. #2
    Join Date
    Nov 2007
    Posts
    754
    South Carolina
    Default Re: 424 Parking brake
    Quote Originally Posted by 424newbie View Post
    Many thanks,
    Randy
    https://webparts.pvassociates.net/cnh/webparts/main.php
    Here is a pic from the above link and part # list.
    Attached Thumbnails Attached Thumbnails 424 Parking brake-001csih-31094-gif
    Attached Files Attached Files
    IHC 424 Diesel
    Ford 917 Flail Mower
  3. #3
    Join Date
    Nov 2007
    Posts
    754
    South Carolina
    Quote Originally Posted by dieselscout80 View Post
    Noticed that link didn't work.
    http://www.caseih.com/northamerica/P...es/search.aspx
    Go to where it says
    "Begin your search for the parts you need right here."
    IHC 424 Diesel
  4. #4
    New Member
    Join Date
    Mar 2011
    Posts
    7
    IH 424
    I've looked at the exploded view a few times and just noticed there is a part shown that I do not have. The PLATE, brake lock lever stop number 34 in the list. Not sure what it does exactly or where it fits in with the other parts. Guess I need to go to a tractor show or find one for sale locally to take some pictures and measurements. Looks like something I can fabricate.
    Randy
  5. #5
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,208
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Maybe check with "Jeff424", in the above for now thread, and see if his still has it on his. Maybe get some measurements..??
    If you've done any brakework on yours, maybe help him out with some pointers... I'm going by a similar 240 model I have, and it's 25 miles away at the moment..., but basically the same.
  6. #6
    New Member
    Join Date
    Apr 2011
    Posts
    7
    International 424
    Default
    Unfortunately my parking brake is missing completely. I wish I could be of some help.
  7. #7
    Member
    Join Date
    Apr 2011
    Posts
    34
    Indiana
    Case-IH 5240
    The top part of the lever hooks behind this plate to keep the lever in the storage position. The spring holds the lever in the engaged position. I hope this makes sense.
    If it's stuck ...force it, if it breaks ...you needed a new one anyway
Similar Threads
  1. Parking Brake adjustable? 755/855/955
    By Snowman9000 in forum John Deere Owning/Operating
    Last Post: 04-16-2010, 11:18 AM
  2. Parking Brake Won't Stay Set
    By jnelson in forum Cub Cadet Tractors
    Last Post: 04-11-2010, 08:41 PM
  3. Parking brake light or buzzer
    By Dennis5 in forum Kubota Owning/Operating
    Last Post: 02-11-2010, 02:32 PM
  4. Parking Brake Light
    By the fox 1940 in forum Kioti Owning/Operating
    Last Post: 10-03-2009, 06:33 PM
  5. PARKING BRAKE ON INDICATOR LIGHT on BX Tractors
    By Chuxster in forum Kubota Owning/Operating
    Last Post: 06-17-2005, 07:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
