Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    JRF
    JRF is offline
    New Member
    Join Date
    Jan 2003
    Posts
    11
    South Carolina
    Default IH 255 Compact tractor
    Need as much information as possible on a IH 255 compact tractor. Local auction has 1 and I may be interested in it. What H.P.? Engine? Power steering? 2 or 4 wd? Advantages and Disadvantages?
    Any info. would be greatly appreciated. Thanks in advance. JRF
  2. #2
    Join Date
    Apr 2001
    Posts
    1,656
    Cambridge New York (north of Albany, next to Vermont)
    Kubota L4630, with cab and loader, 1951 Ferguson TO-20, 1967 Oliver 1550 with fel
    Default Re: IH 255 Compact tractor
    The Case-IH 255 was made between 1986 and 1990. It has a Mitsubishi Diesel rated at 21 hp at the pto.
  3. #3
    Join Date
    Nov 2002
    Posts
    711
    Strasburg, OH
    I have a Case/ IH 244............One size smaller than the 255..........I've run it 5 years with no problems.......540/1000 pto (2 stage clutch) Live hyd, no p. steering, mine is 2wd but they were made in 4x4 models also. I run a 5' brush hog as well as a 6' rear mount finish mower with no problems power wise. I also use a 6' box blade occaisionally with good results. I just got a good deal on a NH TC40 or I wouldn't be selling my 244. All in all a decent little tractor and a friend bought a used 255 based on my good luck with my 244. His has alot of hours but still performs well..........Tom
  4. #4
    Join Date
    May 2001
    Posts
    169
    North Idaho, USA
    2000 Kubota L4610
    I bought one in new 88, a 4x4, gear transmission, power steering, with loader. I paid dearly, almost 14,000 (where was the internet when I needed it?)
    It was pretty reliable, I sold it last year for 8000. with 650 hours on it. I took pretty good care of it (see pictures) It was sad to see it hauled off by a stranger, but the L4610 Kubota eased the pain somewhat (ha, I danced with joy is more like it)
    The Case is fine if you need a small tractor.
    It is very economical to run, but heaven help you if you need to buy specialty parts (VERY expensive)
    The transmission was the weak point on mine.
    Attached Images Attached Images
  5. #5
    Join Date
    May 2001
    Posts
    169
    North Idaho, USA
    2000 Kubota L4610
    Another view of the 88 255 Case/International
  6. #6
    Gold Member
    Join Date
    Mar 2001
    Posts
    414
    Lake View,N.Y.(WNY)
    International 184(1980),KIOTI DK40(2002))
    I considered one that was being auctioned off,I did some research and found that parts for it were getting hard to find.
    I thought the build seemed a little light and the price it went for 10K was too high considering those things and the condition.
    Ended up buying a new Kioti to compliment my IH 184 and it has been a great machine.
    People just seem to be asking way too much for used compacts so a new machine for a little more was the way to go for me........Mike
  7. #7
    Join Date
    Jan 2002
    Posts
    1,483
    Lancaster PA
    Yanmar 186D
    I noticed that the local JD dealers are running specials on the 4010 with hydrostatic transmission for just over 9K. Kind of makes you think about spending too much on questionable used tractor. And the parts are easier to get too.
    Chris
  8. #8
    New Member
    Join Date
    Feb 2010
    Posts
    1
    Hello, I have a nice Case IH 255 for sale that runs like new. I am in Bowling Green, KY and I can send you pictures. Asking $4200 and it has the quick attach front hydraulic grader blade and roof canopy. Thanks Kevin Rector. Email me at Hitechman94@insightbb.com
  9. #9
    New Member
    Join Date
    Aug 2010
    Posts
    1
    i have a 255 where do u buy the connecting rod on the piston?
  10. #10
    Veteran Member Kernopelli's Avatar
    Join Date
    Oct 2006
    Posts
    1,333
    Carterville, Illinois
    Mitsubishi MTE2000D, Dig It 258 Backhoe
    The 254/255's were built for IH/CIH by Mitsubishi ( both are great tractors in my opinion) your 255 has a Mitsubishi K3E engine. The first place to check is generally a Case IH parts dealer but they may tell you that those parts are unavailable/discontinued,etc.... if you can not find them from the dealer, contact a Mitsubishi parts supplier like Len Scheaffer http://www.japanesetractorparts.com/index.htm , he will undoubtedly be able to get it for you and at a reasonable price. In fact, Len got me a connecting rod for a very similar K3F engine a couple of years ago and I had it within a few days.
    Darryl
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
