Results 11 to 20 of 20
03-06-2012, 01:28 AM #11New Member
- Join Date
- Mar 2012
- Posts
- 2
- Location
- tennyson,in
- Tractor
- international 424
Re: International 424 aux valve question
yes i do have the valves you are talking about like one that the yellow tractor has in the picture here i can turn them and the front end still goes up and down and the rear does not untill the front end loader is all the way up and then it moves very slow i was thanking i could put a spool valve on the front end load it will take care of it but not sure any help on this ideal
12-03-2012, 10:47 AM #12New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Mt. Airy, NC
- Tractor
- International 2424
I'm kinda dropping in here late but I have a 2424 with out the auxillary valves, how would you go about just tapping into the Hyd system to run a wood splitter? I had a Super A before that I bought a block to go behind the hydraulic manifold and then just plumbed into the block... Is there anything like that for the 2424? I'm not trying to over simplify but I also don't won't to over complicate. Any help would be appreciated.
Eric
12-03-2012, 11:04 AM #13Silver Member
- Join Date
- Dec 2011
- Posts
- 200
Hi Eric does your log splitter have its own control valve, if so it could be done!!come back to me an I'll post the details for supply and return!!
12-03-2012, 11:31 AM #14New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Mt. Airy, NC
- Tractor
yes, it has it's on control valve. I believe all I need is a way to tap the pressure.
12-03-2012, 05:19 PM #15Silver Member
- Join Date
- Dec 2011
- Posts
- 200
12-03-2012, 07:30 PM #16New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Mt. Airy, NC
- Tractor
Thanks!! That's just what I needed!! I really appreciate the help!
12-03-2012, 11:36 PM #17Silver Member
- Join Date
- Dec 2011
- Posts
- 200
Hi Eric!!
One other thing I forgot (sorry). Where you tap off the supply you need to fit an isolator valve capable of operating at 2500psi so the supply to splitter can be isolated when splitter is not in use but still connected, otherwise the 3 point hitch will not work??
Also I presume the valve on the splitter is of the open circuit variety, this is how it needs to be, a closed circuit type will overload and "cook" the hydraulic system ???.
12-04-2012, 07:03 AM #18New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Mt. Airy, NC
- Tractor
I shouldn't assume, but I "assume" the valve is open center. It worked good on the Super A and that is open center. I figured if it was closed it would have bogged the engine out or blew something out. Is this the same port where a Loader would tap in? If so then the "Power beyond" on the loader valve is what allows someone to use the loader and the 3 point hitch, correct?
Sorry for all the questions, but I appreciate the assistance.
12-04-2012, 07:13 AM #19Silver Member
- Join Date
- Dec 2011
- Posts
- 200
If it worked on the "A" it will be o/k!!
Yes this is the loader tapping and that pipe work includes the isolator valve to turn loader off when using the hitch!!
12-04-2012, 07:19 AM #20New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Mt. Airy, NC
- Tractor
Thanks! Very helpful!
Similar Threads
Open center Closed center?
By BobQ in forum HydraulicsReplies: 61Last Post: 04-01-2013, 06:39 PM -
Loader Kubota FEL with 3rd Function Valve
By rjkobbeman in forum Kubota Owning/OperatingReplies: 5Last Post: 01-26-2012, 12:14 AM -
Backhoe hydraulic plumbing
By BJN644 in forum Kioti Owning/OperatingReplies: 24Last Post: 09-18-2010, 03:37 PM -
B7100 w/ B219 Loader: Valve Question
By ojaikubota in forum Kubota Owning/OperatingReplies: 3Last Post: 12-02-2008, 10:19 PM -
4500 remote hydraulics
By T King in forum New Holland Owning/OperatingReplies: 5Last Post: 11-03-2007, 12:44 AM
