Results 1 to 3 of 3
  1. #1
    Veteran Member scesnick's Avatar
    Join Date
    Sep 2004
    Posts
    1,398
    Garrett County Md. ( Western Md.)
    Kubota MX5100
    Default Case 580B question
    I have a 580B backhoe that spun bearing last yr. We pulled the motor and fixed it and now the motor runs just fine. But, It seems that it developed a pretty good leak right where the motor and the bell housing connect. It is hydro fluid not engine oil.
    I am certainly no mechanic but isn't that area dry and therefore it doesn't need a gasket? Why would I have hyro fluid leaking from there.
    Also, the backhoe didn't seem to want to move too well, especially in higher gears, like most older hoes. So, I changed the terrible looking hyro oil ( hy-trans untra)with new. It seemed to help a bit. But, I did not change the hydro filter. I can't seem to find the part # for it. Would changing this filter also help the hoe backhoe move easier or would it just be minimal? Thanks.
    Father, GNCC racer, KTM rider, Bow hunter, Farm owner.
    Kubota MX5100
    Dodge 2500 CTD
    Yamaha YZ 250
  2. #2
    Join Date
    Jan 2009
    Posts
    1,514
    Rushville, Ohio
    Massey 180 Diesel
    Default Re: Case 580B question
    Power shuttle models show a gasket in between the engine, and torque tube.
    Probably best to go to Case Construction, and determine which particular model 580B you have.
    CASE
    Click on "parts and service", in the menu bar, then "search for parts." Type in your model number, then have a look see, and find what you have.
    Attached Thumbnails Attached Thumbnails Case 580B question-001csc-147727.gif
  3. #3
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,849
    central New York
    all makes and models
    Did you replace the front shaft seal?
    We always count on replacing the front transmission seal any time a engine is split for the transmission.
Similar Threads
  1. Case 585 MCV Question
    By Four Stop in forum Case-IH
    Last Post: 12-17-2010, 04:01 PM
  2. Case M160 mower (built by Woods I think) drive pulley question
    By pjesson in forum General Lawn & Garden
    Last Post: 08-19-2010, 10:50 AM
  3. Case 580B won't crank
    By tomttomtom in forum Case-IH
    Last Post: 09-28-2009, 11:57 AM
  4. Case backhoe 580B "Construction King"
    By jgh in forum Construction Equipment
    Last Post: 06-07-2009, 10:30 PM
  5. CASE 580B
    By h2onut in forum Construction Equipment
    Last Post: 12-07-2008, 06:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
