nimblemotors
- Joined
- Sep 14, 2011
- Messages
- 104
- Location
- Sacramento, California
- Tractor
- Case 530 CK Sold, Ford Ranger DIY Project
Hello, I am the proud new owner of what I believe is a Case 530 CK.
However, the seller thought it was a 1953, and the 530 CK was '60-67.
Looking at tractordata serial numbers, the one on my dataplate isn't even close, it is a 4063xxx. It certainly looks like a 530 CK from other pictures I've seen. I have attached a picture of it. I don't think it has a "shuttle" though, no lever for it that I see. Could this be an older 530 tractor that a backhoe was attached to?
This is my first equipment, will be using it to build a house, level the ground, digging etc.
I have almost no experience with hydraulics, I hope you guys can help me out, as this thing is old and will need a lot of work I'm sure.
My first problem besides the ID, is the engine will stall when the backhoe tries to actually dig, i.e. put a real load on it. It operates fine just moving the backhoe around. What might be the cause of this? the pump is bad?
The gas engine itself seems to run good and rev up, and drives around OK.
Also have one of the stablizer arms that doesn't lift the tractor, it just kinda hisses when the load is on it and stops moving. The cylinder leaking?
Appreciate any help, quite excited to play with my new big boy toy!
