Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    1
    Scobey, Mt
    Default 4366 hydraulics
    I have a 4366 IH and want to pull a air drill with it. Can anyone tell me what I have to do to make my hydraulics work with the hydraulic fan? Thank you.
  2. #2
    Join Date
    Jan 2012
    Posts
    600
    Winchester Ky
    Allis Chalmers ED 40
    Default Re: 4366 hydraulics
    Does your tractor not have remote valves?
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng8090
    If the fan is rotated by a hyd motor, then you need a supply of fluid through a motor valve.
    It depend on what you have now. Can you describe your hyd system, such as, I only have a hyd pump and 3pt, or something similar.
    If you do have remotes, you plug in the hyd hoses to the remotes and bungee the valve spool open for hyd fan operation.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
Similar Threads
  1. Shibaura D23 hydraulics jerky
    By Katydave in forum Hydraulics
    Last Post: 01-31-2016, 10:06 PM
  2. Ford 1710 rear hydraulics slow/not working
    By Minorhero in forum Hydraulics
    Last Post: 03-28-2010, 12:56 AM
  3. Mahindra 4005 Hydraulics
    By dnetherland in forum Hydraulics
    Last Post: 02-22-2010, 01:28 PM
  4. FEL Hydraulics
    By Bob Ha in forum Hydraulics
    Last Post: 10-26-2009, 10:12 PM
  5. Help with Hydraulics
    By Anonymous Poster in forum Projects
    Last Post: 04-08-2003, 08:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
