Results 1 to 4 of 4
  1. #1
    Join Date
    Jul 2011
    Posts
    59
    IH 684
    Default Case IH 885 Westendorf Loader Mounts
    Had a Case IH 885 follow me home from an auction this spring and recently purchased a Westendorf WL-21 loader for it. It came with mounts off of a John Deere 4020 that I am planning in trying to adapt. The problem I am hanging is how the mounts are supposed to go on the rear because the cab is in the way. I was hoping someone had a 885 with a loader that they could send me some pictures of the rear mounts as I am having a tough time finding any. I have not tried calling Westendorf yet but I am guessing they they won't be willing to send me diagrams of the mounts so I won't have to purchase them. Thanks.
  2. #2
    Member nolewatcher's Avatar
    Join Date
    Jun 2009
    Posts
    32
    North Florida
    5420 JD and 790 JD
    Default Re: Case IH 885 Westendorf Loader Mounts
    I had a David Brown 880. This company was bought out by Case IH, and the 885 had most of the same features, sizes, weight, etc. that the 880 had. In fact the 885 engine was the 880 engine without the cylinder sleeves. I found out that when I couldn't get sleeves for the 880. Anyway...I put a loader on the 880. Had the same problem with the mounts. I finally just took the loader and tractor to a local welder and he made mounts for it. They worked real well. He ended up mounting it closer to the front of the tractor than I had considered doing. I went on Google and looked at Case 885's with loaders, and I see others did the same thing. Here is one w/o a cab....
    Attached Thumbnails Attached Thumbnails Case IH 885 Westendorf Loader Mounts-1978_case_885_david_brown_tractor-jpg
  3. #3
    Join Date
    Jul 2011
    Posts
    59
    IH 684
    Default
    Thanks for the response. My tractor is a little different. It is a 1990 Case International 885. It gets really confusing with all the different 885's. I attached a pic of the Case IH 885. I also finally found a picture of what the mounts are supposed to look like (I think anyways).
    Attached Thumbnails Attached Thumbnails Case IH 885 Westendorf Loader Mounts-image-964309172-jpg   Case IH 885 Westendorf Loader Mounts-image-203720062-jpg
  4. #4
    Gold Member
    Join Date
    Feb 2011
    Posts
    405
    princeton nc.
    JD 2320
    those are the front frame mounts, you are totally on your own to tie the loader frame to the rearend. which is NEEDED! those mounts bolt to the transmisson housing(the bellhousing right behind the engine) just in front of the cab. straight down from where the hood has 885 on it.
    The are provisions with the mounts in the picture to attach a subframe from the loader mounts to the rearend.The provisions are the lower 3-4 bolt holes on the mounts. But I don't know if Westendorf made a rear subframe for it, every westendorf loader I have ever seen did not.
    and the Westendorf mount look like a crappy design, they give no support to the frontend. the engine in the 885 is a stressed member meaning it IS the frame for the tractor. the mounts shown only have a single bolt tying the fwd rails to the bellhousing portion. this setup will give no support to the engine whenever you try to lift something. the loader will push down on the front axle and try to lift the rear using the engine case and the transmission case as the lever and possibly breaking one/both! the trans mount portion needs to be rigidly tied to the front axle bolster AND the rear axle. to keep from breaking the tractor in half!
    2010 JD 2320, 200cx, Frontier 1060R RFM, 2048 BB, LR1072 rake, IMatch, 5 suitcase weights.
    NEED MORE IMPLEMENTS!
Similar Threads
  1. Conversion from Cub Cadet 7275 to Case IH 1140
    By americanboy in forum Cub Cadet Tractors
    Last Post: 11-09-2015, 09:15 PM
  2. Mahindra 8560 or Case IH Farmall
    By jwcinpk in forum Mahindra Buying/Pricing
    Last Post: 02-19-2014, 08:32 PM
  3. tractor shopping - ih case
    By jomar215 in forum Case-IH
    Last Post: 02-27-2012, 08:02 AM
  4. New Case IH Owner
    By RubiconTJ in forum Case-IH
    Last Post: 02-03-2012, 10:16 PM
  5. Buying Advice Case IH 4210
    By ah64_ip29 in forum Case-IH
    Last Post: 08-16-2010, 12:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
