Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    1
    Hamilton Ohio
    1210 David Brown/ Case 1979
    Default 1210 case with no hydraulics but has psi
    I have a 1978 case that has the pressure from the pump to lift and use to lift a 7 foot bush hog we have been using. i have had the pressure tested and it checks out fine, and the tractor tries to lift when you push the lever to take the hydraulics up but now only picks the front of the deck up compared to being able to pick up the whole bush hog without a problem. i think the three way control valve has issues but am not sure and do not want to take it apart until i get a few other ideas
  2. #2
    Gold Member rdbigfarmboy's Avatar
    Join Date
    Jan 2005
    Posts
    428
    Collinwood, TN
    MF, Same,Zetor
    Default Re: 1210 case with no hydraulics but has psi
    Find a David Brown shop manual
  3. #3
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    Sounds like you have a leak in the 3pt lift cylinder.
    Does the tractor have remotes and if so, are they working properly?
    Need more info to better help.
    Mark
    1720 Ford 4x4 w/ 7108 FEL
    Case 1845 Uni-Loader NO it's NOT a "C"
    190C John Deere
    Various implements, some store bought, some home made.
  4. #4
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    I've attached a parts breakdown below.
    Item 17 and 18 are what you need if the 3pt cylinder is bypassing.
    Mark
    Attached Files Attached Files
    190C John Deere
Similar Threads
  1. Case IH Farmall 45 HST vs Kubota L3940HST
    By deltabowhunter in forum Buying/Pricing/Comparisons
    Last Post: 01-03-2016, 09:27 AM
  2. Replies: 13
    Last Post: 01-08-2011, 09:27 AM
  3. Ford 1210 Hydraulics
    By Harbruce in forum Hydraulics
    Last Post: 05-04-2009, 10:19 PM
  4. Adding Auxiliary Hydraulics to Case Skid Steer
    By rmhmhm3 in forum Construction Equipment
    Last Post: 11-25-2004, 12:48 AM
  5. Replies: 0
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
