Results 1 to 4 of 4
09-06-2012, 10:20 PM #1New Member
- Join Date
- Apr 2012
- Posts
- 20
- Location
- Monticello, MN
- Tractor
- '71 International 444
IH 444 3ph/draft control lever removal?
Anyone happen to know how these levers are removed? My shop manual doesn't cover this. It does cover removing the shaft from the case/reservior, but not just the levers. I would guess that other models are similar to the 444.
There's one nut on the end of the shaft. I removed that nut, thinking that the levers would slide off the end, but they don't budge. Tried prying a bit, but don't want to bend or break anything. Are these pressed on?
I'm trying to get the right brake housing off, but there's a big suction line for the aux hyd pump in the way. Can't get wrenches on to remove the hyd hose because this lift quadrant is in the way. Arrrghh.
09-08-2012, 10:58 AM #2Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,513
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
10-08-2012, 09:31 AM #3
Re: IH 444 3ph/draft control lever removal?
What exactly does the draft control do?
10-08-2012, 02:21 PM #4Silver Member
- Join Date
- Dec 2011
- Posts
- 192
You need to remove plate under seat, on top of hydraulic housing and dismantle from inside.
Briefly, draft control is a means of controlling soil engaging implements to give a constant depth whilst providing some weight transfer from implement onto tractor rear wheels to aid traction, ( this statement assumes constant soil conditions, but in reality conditions in a field can vary and as such so does the draft force on implements and tractor for a given lever setting, the operator can adjust his draft control lever to compensate).
Similar Threads
Position control lever stuck in draft position on ford 2000
By kdmitch in forum Parts/RepairsReplies: 4Last Post: 09-19-2011, 02:47 PM -
3-Point Hitch FORD 2000 DRAFT control SPRING REMOVAL
By jaygeeoz in forum New Holland Owning/OperatingReplies: 1Last Post: 04-19-2011, 12:01 AM -
draft control, military draft, & draft beer
By PineRidge in forum AttachmentsReplies: 23Last Post: 05-19-2006, 09:40 PM -
M4900 3PH Hydraulics and Draft/Mixed Control
By LeadPoison in forum Kubota Owning/OperatingReplies: 9Last Post: 04-07-2006, 08:36 PM -
3PH control lever
By jdrotert in forum Kubota Owning/OperatingReplies: 2Last Post: 07-10-2001, 07:48 PM
