Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Oct 2012
    Posts
    13
    PA
    Case 530 loader
    Default 530 Hydraulics
    Hi, I'm a new member and I had a question, I'm trying to hook up a woods backhoe to a Case 530 Loader only with a 3 point hitch and I'm not sure where to hook the hydralic lines to. It had two remote fittings at the rear that the manual says were for a cylinder, I hooked up to them but when I pull back on the rh. outer handle to operate it, it puts a load on the motor. I think maybe I have to rout a return line into someware else, not sure. I have pics if needed. Any help would greatly be appericated.
    Thanks, GMT
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    J_J
    J_J is offline
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,656
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 530 Hydraulics
    If you can get fluid to the BH, then you can run the BH return to the filler cap, or a return hose.
    Recheck your QD's.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #3
    New Member
    Join Date
    Oct 2012
    Posts
    13
    PA
    Case 530 loader
    Thanks JJ, both QD's, male, female and hoses are brand new. The book says the outer lever forward pressurizes the top fitting and back the bottom, so i did just that, ran one from the top and ran the other to the tee at the filter as a return and that didn't seem to work either. The hoses come from an aux. valve in front of the steering wheel panel and I didn't know if that was a seperate circut or not.
    GMT
Similar Threads
  1. Looking at a 530 CK
    By MMH in forum Construction Equipment
    Last Post: 12-30-2011, 07:55 AM
  2. Bobcat 530
    By john baker in forum Bobcat Construction Equipment
    Last Post: 12-13-2011, 09:42 PM
  3. Case 530
    By Big_Cajun in forum Case-IH
    Last Post: 06-08-2006, 10:31 AM
  4. Case 530
    By Big_Cajun in forum Buying/Pricing/Comparisons
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
