1466 Turbo
   / 1466 Turbo #1
nkennison
Cecilia,Louisiana
Ford 4000 Case
My International 1466Turbo running bad and just shuts off.
Could it be trash in diesel?
   / 1466 Turbo #2
Welcome to the forum. Have you cleaned the fuel filter and air filter and is the fuel turned on. What color of exhaust. Black, blue, white, clear...
   / 1466 Turbo
Changed fuel filters recently,exhaust clear.
Did not check air filter yet. Had to come to the old job.
   / 1466 Turbo #4
I would check the air filter but I doubt that is the problem if it has clear exhaust. Pluged air intake causes black smoke. Does it shut off after a constant time?
   / 1466 Turbo
It was running great.All at once started missing.The area I was plowing was rough, that's why I thought might be rust or trash from tank.
   / 1466 Turbo #6
There might be something stuck in the injectors then. Probably need to clean them.
