Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    2
    new zealand
    ford 6610
    Default 585 jumping out of gear
    I Have a 585 that had been sitting unused for more than a year, and when I got it started up it wont move off if there is any weight on it if I ease the clutch out but will if I drop the clutch. Any ideas?
  2. #2
    Join Date
    Dec 2011
    Posts
    226
    Default Re: 585 jumping out of gear
    Sound like a problem with the clutch, probably with sitting for a while there may be some rusting on the splines.
    Sound like to fix you will need to split tractor and derust splines etc then apply special lubricant to clutch shaft and disc splines
    You ca n remove an inspection plate below the clutch housing and have a look at what is going on!!
Similar Threads
  1. PTO jumping out of gear
    By PD18 in forum New Holland Owning/Operating
    Last Post: 09-04-2014, 11:19 AM
  2. PTO Gear keeps jumping out of gear
    By Buster747 in forum Ford Vintage Tractors
    Last Post: 10-25-2012, 02:45 PM
  3. case 585 won't go into gear
    By apqhfarm in forum Case-IH
    Last Post: 06-27-2011, 01:58 PM
  4. PTO JUMPING OUT OF GEAR
    By GATOR ENVIRO in forum Parts/Repairs
    Last Post: 09-21-2010, 10:53 AM
  5. L4200 Jumping out of gear
    By mopargocar in forum Kubota Owning/Operating
    Last Post: 07-18-2010, 12:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
