Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    Default 444 pto And hydraulic issue
    So here's the scoop. 69' or 70' fish (serial number plate is missing) 444 gas burner, 1501 fel . Have hydraulic fluid passing to crank case pulled pump getting new seal hope that fixes the problem there. Mostly concerned with PTO can't seem to engage it unless rpm is way low even have to kill tractor sometimes and restart with it engaged attempted clutch pedal adjustment today hope that helps. But even so the PTO will jump out of gear particularly when I have digger on it. What could be the cause and how to fix ? Have shop manual and owners manual. I have been searching all over for a thread or something on this. I have hydraulic system drained and pump off to replace seal hoping to fix both issues at the same time. Can someone help ? All input is appreciated.
  2. #2
    Super Member
    Join Date
    Apr 2000
    Posts
    6,597
    central New York
    all makes and models
    Default Re: 444 pto And hydraulic issue
    That tractor uses a two stage clutch, the first or top two thirds deals with the transmission. The bottom third works the PTO. It could be out of adjustment or it might be bad.
  3. #3
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    Quote Originally Posted by art View Post
    Yeah I'm thinking its probably bad just have to get the pump back on it and fire it up and see if the adjustment did the trick. I guess I'm just hoping for an easier fix. You know how it is just hoping not to tear into the tractor
  4. #4
    Gold Member
    Join Date
    Nov 2012
    Posts
    255
    Newark, de
    International 424
    I have never heard of a 2 stage clutch that uses 2/3 of the clutch for Trans and the rest for the pto.
    I have a 424 that is the same clutch system. It uses a dual disc system One disc for the transmission, and the other for the PTO. The pedal will disengage the transmission when depressed, then the PTO when fully depressed.
    Make sure you adjust the pedal properly. The Clutch assembly's are expensive about 800 bucks for the plate, bearing and 2 discs.
  5. #5
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    Quote Originally Posted by sox3 View Post
    Well I fixed the hydraulic issue with a new seal on the pump and I tried the clutch adjustment I made and the PTO still stays live so now on to the clutch itself. I have a service manual but if you know what its all about I'll listen.
  6. #6
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    See my reply below
  7. #7
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    No longer Searching. Mahindra 3016 Shuttle
    On an off-hand chance, remove the clutch cover and look at the bolts holding the clutch assymbly to the flywheel. Look for a broken bolt or possibly a bolt that loosened and backed out.
    If you find a broken bolt, not just any bolt will replace it. Use factory replacerment bolt.
  8. #8
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    Would that cause the PTO yo stay "live" ? It also jumps out if there is a load put on it (shredder,digger ) I have read the manual but there really isn't "trouble shooting" outlined for this. I believe that the PTO is a continuous running with a dual stage clutch
  9. #9
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    I am not certain about whether pto would stay running or not. I went to stop with my IH 444 and initially just depressed clutch halfway and nothing happened. The tractor continued forward until I stomped on clutch pedal. I checked the pedal adjustment and all was fine. I was told to check for a broken bolt by a tractor mechanic and he was correct. One bolt had sheared the head off. I found the bolthead when I removed the cover.
    Surprisingly, I was able to grasp the remaining bolt shank with vise grips and back it out. The length and grade/ thread have to be exact, so use a factory replacement bolt. Mine cost $2 or so. An expensive bolt, but cheap repair.
  10. #10
    New Member
    Join Date
    Jun 2013
    Posts
    11
    Marion, tx
    international 444
    Thanks I'll let ya know how that works and anything else I figure out along the way.
Similar Threads
  1. Replies: 7
    Last Post: 06-25-2015, 01:19 PM
  2. 1962 JD 3010 gas w/ loader - issue with the PTO drive...
    By allwet in forum John Deere Owning/Operating
    Last Post: 06-27-2013, 08:17 AM
  3. LA140 w/intermittent PTO, melted PTO Clutch Switch and blown 20A fuse
    By Juan Deere in forum John Deere Lawn & Garden
    Last Post: 06-26-2013, 04:23 PM
  4. KAMA PTO selector issue
    By Paddy in forum Chinese Tractors
    Last Post: 05-07-2013, 09:49 AM
  5. MF1240 PTO ISSUE
    By DONALDK in forum Parts/Repairs
    Last Post: 04-25-2013, 07:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
