Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Join Date
    Oct 2011
    Posts
    66
    Case Farmall IH 60
    Default Re: FARMALL 55A PROBLEMS
    How did you check the wiring? I would unplug the battery and feel by hand every electrical wire. One could have been chewed or nicked and only shorting intermittently. While feeling all the wires check all the connections for rust and grounding.
    I also would second checking the operator presence switch under your seat. These do go bad and connections go bad on them for many different types of equipment.
    I would hate to go through and replace everything only to find out it was something simple, which is what it sounds like.
    Are you working in extreme heat or dusty conditions?
    I feel your pain! Tracing a phantom eletrical problem is upsetting! I did that years ago on a toyota. Found the issue was a ground wire was broken in the brake system. Best!
  2. #22
    Join Date
    Jul 2010
    Posts
    2,422
    Pacific Northwest
    Don't forget to check grounds also. I had a Gravely tractor that had a loose ground that would run fine, then just turn off... Tightened the connection (after looking for loose connections for awhile) and all was good after that.
    2007 Kubota L3130, LA723 FEL
    Land Pride FDR1672 rear finish mower, Frontier RB1172, Koyker KB60 BH
    Pallet forks, Golf cart canopy bolted to ROPS, 9" & 12" PHD
    2016 Ferris IS700Z 52" Briggs 27hp commercial turf series
  3. #23
    New Member dieseljay's Avatar
    Join Date
    Jun 2011
    Posts
    9
    International 786
    Default
    Have you had any luck finding your problem with the engine shutting down. After looking through the fuel shut off schematic I would suspect that your problem might be in the operator safety module. It is located under the hood, between the engine and the fuel tank. There is two boxes in this location. One is the alarm for the operator presence and the other is the operator safety module. It appears to control the ground for the fuel shut off relay and takes inputs from the operator presence switch. If needed I could send you a copy of this schematic.
  4. #24
    Platinum Member farmall 55a case's Avatar
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    Thanks for the advice everyone! Still no luck! My ground cable was a little loose tho! I tightened it up but still no luck! I need to look into that safety box by the alarm! I don't recall seeing one there tho! Just the alarm and fuse box! I will have to look at it again when I get home! Thanks again everyone you all have been really helpful!!
  5. #25
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    Quote Originally Posted by dieseljay View Post
    Is this what your talking about?
    FARMALL 55A PROBLEMS-forumrunner_20131005_094454-png
  6. #26
    Join Date
    Oct 2011
    Posts
    66
    Case Farmall IH 60
    I believe that is what he is talking about. Can you remove it and check the wiring to ensure it is not corroded? I would follow that wire harness as well. Is there someone nearby you could swap switches with to find out if this is truly the issue?
  7. #27
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    I wish there was some one to swap with! Headed to the dealer now to see what they have to say about it!
  8. #28
    Join Date
    Jun 2011
    Posts
    9
    International 786
    Default
    That is the module I was talking about but after looking at it again realized it is for the lights. I thought that it was the safety module knowing the one beside it is the safety alarm as I have it unplugged to avoid listening to the annoying alarm. Kinda thought that case would have put the two modules that are in the same circuit close together, Sorry for the confusion. I could not find the safety module. Might be under the dash. Doesn't show a clear location in the parts break down but according to the schematic it has 6 pins. Again sorry if I steered you in the wrong direction
  9. #29
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    Nope that's fine! Now I know what it is! The dealer said it was under the dash I have it all taken apart and still can't find it! But what is this? It starts and runs with or without it?
    FARMALL 55A PROBLEMS-forumrunner_20131009_175900-png
    FARMALL 55A PROBLEMS-forumrunner_20131009_175942-png
    And I have two wires that don't go anywhere! The green wire is hot when the key is on!?
    FARMALL 55A PROBLEMS-forumrunner_20131009_180111-png
    FARMALL 55A PROBLEMS-forumrunner_20131009_180135-png
    Thanks for any info!
  10. #30
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    OK I have in my hand a module fuel control! In the parts manual it says and shows it by the relays! Its not there! Where is it at? I think they printed me off a page for the dx55 not sure tho! Anyways how I have come to the conclusion that this is it is that it dose not smoke out of the exhaust when it dies and I try to start it. The book at the dealer said it was one of two thing. The fuel shutoff solenoid. I replaced that at the beginning of this whole ordeal or the module fuel control so that's where I'm hoping my problem is but I can't find it! All of my wiring and switches are great shape. Just can't find where this control is! Thanks! Any info will be greatly appreciated!
Similar Threads
  1. Farmall M Hydraulic problems
    By Olds25 in forum Case-IH
    Last Post: 12-23-2012, 08:36 PM
  2. Farmall 55A Transmission problems
    By farmboy52 in forum Case-IH
    Last Post: 08-06-2012, 11:32 PM
  3. Farmall model H hydraulic problems
    By Drifter52 in forum Hydraulics
    Last Post: 10-26-2010, 02:08 PM
  4. New Farmall 95 Power Problems
    By emersone in forum Parts/Repairs
    Last Post: 10-23-2009, 06:55 AM
  5. Farmall 130 starting problems fixed
    By upgw in forum Farmall Vintage Tractors
    Last Post: 06-23-2004, 07:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
