Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Join Date
    Apr 2013
    Posts
    52
    Brownsville Kentucky
    none
    Default Re: 970 Case
    Kim,
    There was no surge like you described in previous posts but quite the opposite. When the clutch was pushed the tractor would pull down as if were under a load. This tractor is a white cab model. I did check the lift comparison and everything looked ok. As far as the brakes, I could put the tractor in 3rd gear and in the 3rd PS range and push both brakes as far as I could and it would still pull through the brakes in an idle. Wish you were closer to have been with me....lol!
  2. #22
    Join Date
    Apr 2013
    Posts
    52
    none
    I guess since the 970 isn't going to work out I'm going to keep looking. I'm not a "brand" man. Just looking for a good hay, bush hog, hay feeding tractor. I would like to at least have some that is 55hp at the pto and if it doesn't have a cab I'd like to have a canopy. For any of y'all that have hay operations our cow calf operations, what size and kind of tractors have treated you well?
  3. #23
    Join Date
    Jun 2002
    Posts
    795
    Rozet, Wyoming
    I'm guessing the lack of the surge is a cable adjustment problem, as in the cable isn't pushing the valve in completely. Did the range (1-4) shift OK or did the gears clash? The brakes are self adjusting, if the mechanisms are not seized up. They may just be out of adjustment, or could be worn out. If the park wasn't adjusted up tight at some point and it got run with the park brake on they may be worn completely out. This is probably a tractor that could be fixed up without a lot of time or expense. I wish I could have been there too!
    Kim
  4. #24
    Join Date
    Apr 2013
    Posts
    52
    none
    Man, you definately know more about these tractors than I could dream of. The 1-4 gears would grind some. The PS worked great.
  5. #25
    Join Date
    Jun 2002
    Posts
    795
    Rozet, Wyoming
    That's what I thought. If the inching valve isn't pushed in far enough the gears will still be turning some, thus the gear grinding. I believe a new clutch spring and cable adjustment would fix the tranny issues.
    Kim
  6. #26
    Join Date
    Apr 2013
    Posts
    52
    none
    Think maybe I've counted it out too soon? I know one big expense right off the start and that's a new rear tire. A New Firestone radial 18.4 x 34 here is $1800. That's what the other side has on it.
  7. #27
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,820
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    The OEM tires on our 1976 MF 265 side walls are made up of about 26 flaps on each side due to dry rot. Five years later they are still doing fine. Actually the flaps (where rubber has separated from casing) are a plus since they stick out more when the air pressure gets low.
    The tire dealer talked me out of buying new ones because these 36 year old tires are much harder than new ones so bush hogging is not as likely to give us a flat tire.
  8. #28
    Join Date
    Jun 2002
    Posts
    795
    Rozet, Wyoming
    I'm in the same boat, but mine's just a bias ply. It's a COOP tire with a gash in the sidewall. Still holding but for how long? It's full of calcium chloride too. Both are pretty weathered.
    As for the tractor, maybe. I'd feel bad If you bought it on my recommendation and it turned into a money pit. I sure wouldn't give him $6000 for it. Question is, are you up to doing some fixing? There's risk in buying any used tractor, especially one that old. There would be less risk with buying a standard transmission tractor. The power shift is nice for loader work.
    Kim
  9. #29
    Join Date
    Apr 2013
    Posts
    52
    none
    That's kind of what I was thinking. Now if I could get it for $3500 it may be worth getting and putting some $ into. But at $6000 I'm not interested enough to get it and putting money into it. I'm really wanting something that I can start working and not working on!
  10. #30
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,820
    Murray, KY
    I agree on a lower price.is buying.
    Would a 5000 or 8000 series Ford work?
Similar Threads
  1. Replies: 5
    Last Post: 07-29-2013, 10:50 PM
  2. 3pth for 970 case?
    By Hiawatha22 in forum Attachments
    Last Post: 07-07-2013, 08:22 PM
  3. Got a new(to me) case 580CK Case, old with potential.
    By andrec999 in forum Owning/Operating
    Last Post: 05-31-2013, 05:52 PM
  4. case 2012 its a case!
    By Barry Gridley in forum Case / Ingersoll
    Last Post: 06-28-2011, 06:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
