Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Mississippi
    Case 580C
    Default 1979 Case 580C shuttle transmission slow to engage in forward when cold
    I have a 1979 Case 580C that is slow to engage the shuttle forward drive gear when the machine is cold. If you let it warm up about 10 minutes, it will engage normally and operate fine. No hesitation in engaging the shuttle reverse gear when cold. All hydraulics, bucket and backhoe, operate normally.
    Have checked shuttle fluid level at check point in front of shift lever in floor of cab. Was slightly low, but took less than a quart of Case Hytra trans oil. Did not notice any significant change in gear engagement when machine was started cold.
    Question: !) Is there any other location to check shuttle fluid levels on the 580C? 2) If I need to change the shuttle trans fluid, how many drain ports are there and where are they located?
    Thanks, JT
  2. #2
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    Default Re: 1979 Case 580C shuttle transmission slow to engage in forward when cold
    your are talking a backhoe correct or a tractor
  3. #3
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Mississippi
    Case 580C
    Sorry, it is a 1979 Case 580C Backhoe with shuttle drive, 4 speed, forward and reverse.
  4. #4
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    I had a 73 580b mine had the oppsite problem when it got hot it wouldn't move forward or back i don't know much bout the tranny in them backhoes
  5. #5
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    i would try googling the problem that might help
  6. #6
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Mississippi
    Case 580C
    Thanks. Google referred me to this forum. I am sure there are some very knowledgeable experts on this site that can give me some help when they have time.
  7. #7
    New Member
    Join Date
    Dec 2012
    Posts
    10
    Bridgton
    Case 580c
    um to check the fluid in the shuttle there is a dip stick in the rear of the engine bay near the starter. (Right side of the tractor if your sitting in the cab)
  8. #8
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Mississippi
    Case 580C
    Thanks for the help. It is very much appreciated..
  9. #9
    New Member
    Join Date
    Dec 2011
    Posts
    11
    Case IH 5130
    I think thats normal for them. Need to warm up first.
  10. #10
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,257
    manitoba
    Many
    It is quite normal even in good shape best to let them warm up for 10 minutes .
Similar Threads
  1. 1979 Case 580c transmission problem
    By tdibar in forum Construction Equipment
    Last Post: 08-27-2017, 11:43 AM
  2. 1978 Case 580C power shuttle forward clutch piston
    By ewbaxter in forum Construction Equipment
    Last Post: 06-29-2013, 01:59 PM
  3. 580c case power shuttle problem
    By cobrahatch in forum Parts/Repairs
    Last Post: 09-22-2012, 06:08 PM
  4. Backhoe case 580c year 1979
    By tdibar in forum Case-IH
    Last Post: 02-18-2011, 07:02 PM
  5. Backhoe CASE 580C Shuttle pressures..????
    By bub13147 in forum Case-IH
    Last Post: 07-26-2010, 10:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
