Results 1 to 5 of 5
  1. #1
    Member
    Join Date
    Feb 2011
    Posts
    37
    Benton City, WA
    Case 530
    Default ~1965 Case 530- Starter?
    I believe I've burned the solenoid up, but the starter was getting weak and I believe it'll cost me $200-$300 to rebuild the one on it, can I get something better/cheaper? It got to the point that I couldn't get it to crank fast enough with a good battery, being charged by a vehicle (14v) and 4ga jumper wire from post to starter post.
    I think its a 1965 Case 530 with loader/hoe
    I've found this guy on ebay but I haven't pulled mine out of the tractor yet
    Starter Case Tractor 430 431 530 531 531C 570 580 580B 630 4 148 4 188 G176 G188 | eBay
  2. #2
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    Default Re: ~1965 Case 530- Starter?
    Klitch,
    Just be careful to get the correct number of teeth on the starter bendix, especially if it's a 188 diesel engine. The older engines used a 9 tooth bendix. If no one has ever changed the flywheel ring gear and your starter has the 9 tooth, a 10 tooth (which is MUCH more popular) will NOT work.
    Hope this helps,
    Mark
    1720 Ford 4x4 w/ 7108 FEL
    Case 1845 Uni-Loader NO it's NOT a "C"
    190C John Deere
    Various implements, some store bought, some home made.
  3. #3
    Member
    Join Date
    Feb 2011
    Posts
    37
    Benton City, WA
    Case 530
    Thanks for the advice, I was able to salvage the original starter, I will keep your advice in the back of my mind for when I need to replace the starter. Hopefully I don't have to. I see what you mean by the 10 tooth being more popular.
  4. #4
    New Member
    Join Date
    Apr 2018
    Posts
    7
    Warrensburg
    Case 530CK
    I have a 64 Case 530 CK with the Gasoline engine. any advice on where to find a Replacement Starter or even a rebuild kit?
  5. #5
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,208
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    I don't know that I've ever seen rebuild kits available. Check around and see if you have a local rebuild shop. Unless the armature is toast, it doesn't cost that much to have them rebuilt. We're very fortunate to have a great shop near by. He charges $35, plus parts needed. With bearings, new brushes, etc. it's normally around $60. Along with that, he cleans up the armature, blasts the case, and paints it, with a 1 year warranty. Turn around is normally 24 hrs.
Similar Threads
  1. 1965 Ford 3000 Starter Problems
    By Bharris246 in forum Parts/Repairs
    Last Post: 05-26-2015, 09:44 AM
  2. Case 530
    By Big_Cajun in forum Case-IH
    Last Post: 06-08-2006, 10:31 AM
  3. Case 530
    By Big_Cajun in forum Buying/Pricing/Comparisons
  4. 64 Case 530 CK
    By 67Mopar in forum Parts/Repairs
    Last Post: 07-06-2005, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
