Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    2
    Wisconsin
    Case 530CK
    Default Can anyone identify this gland?
    Hi all,
    I'm resealing/repacking all the hydraulics on a case 530CK that I recently purchased. I ran into a snag when I found that one of the swing cylinders does not have the original gland. I can't find any identification numbers on it to find the matching seal kit.
    The main difference from the original is that the outer wiper is rubber instead of the plastic split ring type on the rest of the cylinders. The inner wiper is the split plastic split type like the original. I'm guessing the gland is from a later model case. The cylinder body is original: bore is 4" and the rod is 1.75".
    Does this look familiar to anyone?
    Thanks
    Chris
    Attached Thumbnails Attached Thumbnails Can anyone identify this gland?-dsc_4027_sm-jpg   Can anyone identify this gland?-dsc_4029_sm-jpg
  2. #2
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    Default Re: Can anyone identify this gland?
    I think what you need is a D95143, though you'll probably have to buy a whole kit to get it.
    G32617 should be the kit number.
    You can go to the Case Construction website, find the online parts tab and type in 32S for the model number. This was the model of the backhoe attachment hooked to the 530CK tractor to verify this information.
    Mark
    1720 Ford 4x4 w/ 7108 FEL
    Case 1845 Uni-Loader NO it's NOT a "C"
    190C John Deere
    Various implements, some store bought, some home made.
  3. #3
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    I hope this PDF file uploads correctly.
    It should help you.
    Mark
    190C John Deere
  4. #4
    New Member
    Join Date
    Oct 2013
    Posts
    2
    Wisconsin
    Case 530CK
    I didn't realize there were two versions of the swing cylinders for this backhoe. Searching for seal kits for the model 32 kept getting me the split wiper kits only. Thanks for your help!
    Only 2 more cylinders on the loader to rebuild, so hopefully no more surprises. I also found that somebody replaced the dipper/crowd rod with a boom rod (7 inches too long). Had to take it to a shop to cut and reweld to correct length.
    Chris
Similar Threads
  1. Leaking gland seal
    By spidersweb in forum Hydraulics
    Last Post: 02-23-2013, 11:11 PM
  2. Loader The loader cylinder cracked at the gland on my kubota B1750HST.
    By richie25rich in forum Owning/Operating
    Last Post: 09-25-2012, 04:45 PM
  3. 580C hydraulic gland removal
    By jw3 in forum Parts/Repairs
    Last Post: 08-06-2011, 08:54 PM
  4. Kubota LA450 FEL Gland Nut
    By cytafex in forum Parts/Repairs
    Last Post: 06-03-2011, 05:29 PM
  5. I busted my gland nut
    By woodchuckie in forum Parts/Repairs
    Last Post: 01-11-2009, 10:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
