Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    7
    midland, mi
    Case International JX1070c
    Default 2007 Case IH JX1070 Bruce
    I have a 2007 Case JX1070c this tractor is used lightly it only has 350 Hours. The last time I used it everything worked fine 2 weeks later I went to use it and the 3 point arms will not move they are in the down position. This model has a device called a quick lift it seems fine. I plan on changing filter hytran oil in the morning. The power steering works fine anyone have any ideas.
  2. #2
    Super Member mguitas's Avatar
    Join Date
    Aug 2011
    Posts
    7,913
    Schuylkill County Pennsylvania
    Massey Ferguson 1423 Hydrostat
    Default Re: 2007 Case IH JX1070 Bruce
    aboard, i'm sure somebody will chime in.
    Massey 1423, 1462 loader, wallenstein Ranch ho gx620, with subframe mount. Deere 710c
  3. #3
    New Member
    Join Date
    Oct 2013
    Posts
    7
    midland, mi
    Thanks this is frustrating hope filter and oil change will help old oil looks brand new clean.
  4. #4
    New Member
    Join Date
    Oct 2013
    Posts
    7
    midland, mi
    Oil and filter change did not work tried several adjustments no results dealer next.
  5. #5
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Welcome to TractorByNet!
    I moved your thread to the Case-IH forum.
    Briana
    TBN Support
  6. #6
    Platinum Member farmall 55a case's Avatar
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    Dose it have a hyd lockout on it?
  7. #7
    New Member
    Join Date
    Oct 2013
    Posts
    7
    midland, mi
    none that I have seen in owners manual everything worked fine parked it in the shed got it out 2 weeks later no hydraulics to rear arms or rear remotes. A CHI dealer told me it may be the Service Control Valve the low pressure valve it it may be stuck. the Service control valve is on the left side just in front of axle.
Similar Threads
  1. Bruce
    By BDA in forum New Member Introductions
    Last Post: 03-14-2012, 04:34 PM
  2. Radio options for 2007 Case 580M??
    By ryebread929 in forum Case-IH
    Last Post: 01-06-2011, 08:44 PM
  3. Bruce
    By Rogerbruce1 in forum New Member Introductions
    Last Post: 11-06-2010, 09:39 PM
  4. Bruce Matheny
    By hunter1954 in forum New Member Introductions
    Last Post: 10-03-2010, 03:30 PM
  5. We Need Bruce Willis
    By skent in forum Related Topics
    Last Post: 07-26-2002, 04:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
