Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    11
    Naples, FL
    1967 Case 580CK
    Default How to rebuild backhoe model 33 valve control box?
    Hi guys, first post! I need some help!
    I recently bought my neighbors 1967 580CK with a 33 backhoe for 2k. besides some rotted hoses and tire issues the biggest problem is the leaks at the backhoe control valves.
    I couldn't test it because of some busted hoses and it was also way to dirty in there to see anything.
    So I uninstalled the whole valve body and cleaned it nicely but now I'm not sure how to proceed.. which seals to replace? Ideally I'd like to replace them all, but an online parts store told me there are 200+ seals in there and it could run me $8-900 to buy them all.. I looked t the diagram in the Case parts website though and I could only see about 10-11 seals/valve so no more than 70-80 seal for the whole thing.
    How to rebuild backhoe model 33 valve control box?-2qclch0-jpg
    What say you?
    Should I take the whole thing apart and replace only the damaged seals?
    Or install it back now that it's cleaned and the hoses are fixed to see where it leaks?
    Thanks in advance for any advice!
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: How to rebuild backhoe model 33 valve control box?
    I would recommend putting it back together and see where the leaks are.
    There are 3 to 4 o-rings between each section.
    There are o-rings on each spool top and bottom.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,706
    Northern, IL
    Branson 2400H, JD X540
    Since you have already removed the valve assembly any way you apply pressure to the inlet and see what leaks? Build pressure slowly in case you missed plugging a flow path. Seals between the sections are typically the pressure and tank lines and can flatten and harden from time and heating cycles.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  4. #4
    New Member
    Join Date
    Oct 2013
    Posts
    11
    Naples, FL
    1967 Case 580CK
    Thanks guys.
    I replaced the spool seal since I already had them ordered, put it all back together and it works, no leaks!
Similar Threads
  1. Replies: 8
    Last Post: 11-24-2012, 09:57 AM
  2. Bobcat 753 Hydraulic Control Valve Rebuild, with pictures
    By dieselfuelonly in forum Parts/Repairs
    Last Post: 09-17-2012, 12:03 AM
  3. Need help rebuild little control valve
    By lhfarm in forum Hydraulics
    Last Post: 09-18-2010, 06:52 PM
  4. Loader Control Valve Rebuild?
    By RFrank in forum Hydraulics
    Last Post: 08-18-2008, 09:18 PM
  5. Valve rebuild for Industrial backhoe
    By Richard in forum Parts/Repairs
    Last Post: 05-27-2004, 09:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
