Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Feb 2014
    Posts
    7
    Colfax, Iowa
    IH 606
    Default new to tractors - IH 606, fast hitch/
    New to tractors, but am looking to buy this 1964 IH 606. Can anyone tell me if this "knuckle" is part of the fast hitch system, is it for the top bar?
    Thanks,
    Jon
    new to tractors - IH 606, fast hitch/-ih606cx-jpg
  2. #2
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: new to tractors - IH 606, fast hitch/
    It has to be part of it. How about a close up shot.
    Murph
  3. #3
    New Member
    Join Date
    Feb 2014
    Posts
    7
    Colfax, Iowa
    IH 606
    Here is picture off another tractor-
    new to tractors - IH 606, fast hitch/-other-hitch-jpg
  4. #4
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,527
    Cumberland Plateau, TN
    Bobcat CT225
    Notice the last picture has 3 point ball arms in the Fast Hitch lower arms. That top clevis is probably for converting and using 3 point hook up. Normal Fast Hitch only used the lower lock-in arms.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  5. #5
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,680
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    It looks to me like the place to hook the top link for a 3pt hitch conversion. Hopefully a fast hitch expert will kow for sure.
  6. #6
    New Member
    Join Date
    Feb 2014
    Posts
    7
    Colfax, Iowa
    IH 606
    yeah, that second picture is not of my (soon to be) tractor, but the one I'm looking at doesnt have the ball arms, but does have the top clevis
  7. #7
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,195
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Being you could get either as shown in the pictures, that is the hook up for the top link. You can get the slide in tong type 3 pt. arms, or a regular 3 point conversion that has a bail across the top with it's own top link. Or, find a salvaged 606 with 3 pt., and change it out.
    The tong type conversion are much more reasonable in price, but you'll probably need the long top link. I know I had to get one for my Super C. Even with that, seems you don't get the geometry of a true 3 pt. hitch. If it's lifted as high as the FH in the first picture, the tail end of the implement will drop after a certain point of lifting. On the other hand, one of the great things about Fast Hitch is, it has down pressure. That would be pretty handy on a tractor that size if you had a HD blade, and grading.
    If you do get it, keep on the look out for FH implements. They usually bring less money, as that's all they fit. There are two category's to the Fast Hitch implements. The smaller one is for Super C's. My 240 has the larger one. There's something like a 1/8" to 3/16 difference in height of the prong. We made spacers to slide in on the bottom of the female part on the tractor out of flat strap, with a turned down tang to keep it from sliding on through. There is a nub sticking down on the prongs, that stops it from going in too far. I can use my Su C's implements on the 240 if I want to.
  8. #8
    New Member
    Join Date
    Feb 2014
    Posts
    7
    Colfax, Iowa
    IH 606
    Thanks Guys- I wil admit to fretting over the purchase (as I don't really know what I'm doing- having a 3 point usable option is good!
Similar Threads
  1. Farmall fast hitch
    By Don62 in forum Build-It Yourself
    Last Post: 04-06-2015, 07:55 AM
  2. Super C Fast hitch
    By tessiers in forum Farmall Vintage Tractors
    Last Post: 02-24-2015, 06:18 PM
  3. grader on fast hitch
    By VTLOWBOY in forum Attachments
    Last Post: 03-17-2013, 09:35 AM
  4. Points for IH Fast Hitch
    By DougKnudson in forum Build-It Yourself
    Last Post: 08-15-2009, 12:55 PM
  5. FAST EZ HITCH ON 2305
    By stmftr in forum John Deere Owning/Operating
    Last Post: 05-04-2009, 02:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
