DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,227
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I don't know if this will help, but Komatsu bought out Dresser, which bought out IH Industrial Equipment. Here is a link to Komatsu https://www.mykomatsu.com/authfiles/login.aspx that by registering may, I say may..., at least get you to a parts catalog. I didn't go any further than this, as I don't have any reason to. But thought I'd forward it on if you care to try.
From looking at a few of the picture from the auction site, and seeing the large hoses coming from the loader control valves, it appears the return lines go in under the seat on the right side. That would tell me the reservoir for the hydraulics is in the diffy housing. I did see a fill plug on the trans cover, but no dipstick like on my 656. Doesn't seem to be any pictures at the right angle to see one either.
I suppose until you get some manuals, you could look for a dipstick of some sort, or check plug on the side of the rear end/trans. housing. I'd even be tempted to stick a clean rod, or something down through the fill plug hole, and get some oil on it. Just make sure it's long enough, so as not to drop inside. With that style shifter, and if it has set outside much, they do have a tendency to take on water.
