Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2011
    Posts
    55
    Default 585 fuel question
    Tractor seems to run out of fuel. It starts stalling out slows down then speeds back up. Sometimes will completely shut off. Its erratic works fine for a few minutes then starts doing it again. I've changed the filters, 1st one had some debris in it. Did not help. Anybody know if there's a screen or something else I can check. Any help would be appreciated.
    Thanks Ray
  2. #2
    New Member
    Join Date
    Nov 2014
    Posts
    3
    Lismore, MN
    JD B
    Default Re: 585 fuel question
    I hope your tractor is like my 560. Take the return line loose and as you run the tractor it will leak. If it runs then the check valve in the reurn line is plugged. The 560's return line is to the bottom of the tank. Some pump will stop pumping if there is too much pressure in the pump. Good luck and I hope this works for you like it did for me. Jim
  3. #3
    Join Date
    Oct 2011
    Posts
    55
    Quote Originally Posted by Inteere View Post
    Thanks Jim, I was not aware of the check valve. I'll give it a try.
    Thanks again, Ray
  4. #4
    Join Date
    Jul 2003
    Posts
    1,930
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    Quote Originally Posted by ARAYT View Post
    Thanks Ray
    Ray, I've got a friend that has a 585 and had the same problem...an "old" farmer down the road from them told them that the fuel line (I believe its the one that has the woven mesh over it) has a tendency to "collapse" when it gets old...as well as I remember its the one that comes out of the fuel pump going up to the injection pump...if it is, its and easy fix, but you will have to bleed the unit once you change it out. Good luck, let us know what happens. BobG in VA
  5. #5
    Join Date
    Oct 2011
    Posts
    55
    Quote Originally Posted by BobG_in_VA View Post
    Thanks Bob. I know the line you are talking about I'll make sure its ok. Its cold here like most everywhere, it will be a few days but I'll let yall know what I find. I appreciate the advise.
    Thanks, Ray
  6. #6
    Join Date
    Oct 2011
    Posts
    55
    Guys I removed all the fuel lines, blew them out and she seems to be running fine. Still have not put her to the test but I believe she is gonna be ok. Thanks again for the help!
    Ray
Similar Threads
  1. fuel inj pump replacement case 585
    By wrenchwizzard in forum Parts/Repairs
    Last Post: 07-25-2014, 11:49 AM
  2. IH 585 hydraulics
    By delchip in forum Case-IH
    Last Post: 02-18-2013, 08:51 PM
  3. Case 585 MCV Question
    By Four Stop in forum Case-IH
    Last Post: 12-17-2010, 04:01 PM
  4. Value of an 04/05 JD 585
    By CT Yankee in forum John Deere Buying/Pricing
    Last Post: 02-14-2008, 04:33 AM
  5. 585 case IH
    By deano68 in forum Buying/Pricing/Comparisons
    Last Post: 08-20-2004, 09:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
