jb35007
i have a 74 case ck 680 and i'm having a hard time stopping this beast the brakes have been bleed and i have a firm pedal but i have to put over 200 lbs of pressure to get this thing to grab and stop the wheels...
so my main question is , is there some sort of hydraulic assist for the braking system that maybe isn't working or that i missed????
there is a round pad bolted on the back of the motor that moves freely when i push the brake levers but i am unsure of it's purpose???
all i know is this can't be the actual way the brake system was designed also down on the brake canister i only get maybe 1/4" travel when the brakes are pulling the rod out.
please help,
jeff
p.s.
i adjusted my emergency brake to where i can barely set it and if i lift the rear tires off the ground and put it in first and forward gear (shuttle shift) the parking brake barely stops the wheels from turning....
please help,
jeff
p.s.
