Case 8420 Baler Tension Spring Replacing
   / Case 8420 Baler Tension Spring Replacing #1
sholtisa
Pittsburgh, PA
Ford
I had one of the four tension springs on my 8420 round baler break. I got the replacement part, but have been unable to find out how to put the spring on. I've tried releasing the tension on the belts but I am still 6 inches or so short. I attached a picture of the spring attached to the top. As far as I can tell the tension bar needs to rotate more to connect the other end. Any suggestions would be appreciated! Hay is on the ground and it broke on the first bale.
